Fuse in M1 Piano?
0 Members and 1 Guest are viewing this topic. Read 1503 times.
BfloDave
Fuse in M1 Piano?
« on: 13 Feb 2014, 02:26 pm »
I don't see an external fuse.  I would like to try an audiophile-type replacement fuse in the unit, if you could provide the current, voltage ratings and length of the fuse.  Thanks in advance.
virtue
  • Making audio lovers audiophiles
    • Virtue Audio
Re: Fuse in M1 Piano?
« Reply #1 on: 24 Feb 2014, 08:39 am »
Hey Dave,
The fuse in inside the IEC jack.  Since it's before the transformer, you really aren't going to gain anything by "improving" it.  You'd be better off improving the wiring in your house ;-)
With hugs,
Seth
