0 Members and 1 Guest are viewing this topic. Read 23420 times.
Levi, it's not always a matter of whether your system draws too much power or not compared to the capacity of the conditioner. The way it was explained to me, the issue is that when you put a big transformer in the AC path, you are bound to lose some speed. That the AVS2000 has a "50lb transformer" that adjusts to different windings on the fly certainly makes its impact on dynamics a concern. The hope is that the benefits outweigh the negatives; if your power is consistently very low (eg. 110v or less), ...
additionally if your speakers are working your amp really hard, so that you are constantly drawing down the amp's capacitance then I think the transformers in front of your amp will do more damage. if the load is fairly benign, or your playback volume doesn't present much of a challenge for the amp/speaker combo then I think the effects will be moot. All in all, Levi, if your happy and it works, don't fret over it! Sometimes it is the things that you don't quite understand, or can't quite explain that drive us nuts. If we understood it all we wouldn't be so neroutic I think.
I am doing my damnedest to get ready to host September but I have a lot of work to do on my system. It still sounds worse than last year when I hosted and I had done a lot of work since then to up it a notch. The devil is in the details!
Does anyone isolate their power conditioner on platforms, cones, etc?Michael
