0 Members and 1 Guest are viewing this topic. Read 6060 times.
The SAE 1000LT was a real bargain at the $200 I purchased one a few years back. Still not that bad at $325 but If you search or wait I bet you can find one cheaper. This is a High Output MC
As for the Grado, you would come out with better sound by buying a Grado Black cartridge and an 8MZ stylus for a total of $160. Much better sound than the Gold and a $70 savings, plus you have a spare stylus for testing out used LP's.
The Emotiva will work fine with either the Denon 301 or the AT OC9. 60db gain is enough for both of them and it has compatible resistance settings that will work for both. If you are willing to wait a short period of time the Denon from Comet Supply is a bargain. It does bass and drums very well in my system. As bacobits said the AT OC9 is also well respected, albeit just a slightly different flavor. As for the Grado, you would come out with better sound by buying a Grado Black cartridge and an 8MZ stylus for a total of $160. Much better sound than the Gold and a $70 savings, plus you have a spare stylus for testing out used LP's.
roscoeiiiI bought right after Christmas after Wayner started talking about it. I bought it to compare against the V-LPS in my office system. That is where I let it break in for over 10 days. I moved it into the main system in place of one of the Vista's just to try it out with the DL-301 Mk II. It is still there about three weeks later running at 60db and 470 ohms. To my ears the Emotiva's 60db setting is a bit louder than the Vista's by a couple of db's. It is neither thin sounding or noisy. Also tried it with the Grado 8MZ cartridge and it did fine with that also at 40db. Like Wayner has said it is in fact a bargain. If you want even more flexibility then the Vista is the way to go. If the Emotiva has resistance settings that work with the cartridge of your choice then buy it as a starting point. It has a 30 trial period.
The current cartridge I have is the original blue point...it has about 200 hours...Ive had it for a long time...didnt play a lot of vinyl over the years and just started back...been playing a lot CDs and fooling with computer audio...and a pro drummer. It sounds ok, not sure...just want to look for something that is dynamic and does the drums well without falling apart..the blue point in my setup does this well...just haven't kept up with what is available out...so thought I would ask...heard good things about the grados, audio technica at440mla, Ortofon blue2 m...thank you all..keep them coming..Greg
