Dual voice coil driver
0 Members and 1 Guest are viewing this topic. Read 1266 times.
Vlad
« on: 10 Feb 2014, 11:16 pm »
Hi Louis,
Is it possible to order a driver with a dual voice coil (e.g. 2x8 ohm)? How hard would be to make such driver?
I understand that it might be special-order/custom/higher-price kind of deal.
Vlad
Louis O
Re: Dual voice coil driver
« Reply #1 on: 12 Feb 2014, 08:25 pm »
Hi Vlad,
I may be able to do it, but such a driver would may require me build large quantities of this type of driver to be feasible.
Louis
Vlad
« Reply #2 on: 13 Feb 2014, 12:02 am »
How do you wind this driver? I assume both coils are wound together in parallel, so if they are connected in
series (or parallel), they would perform as a regular single-coil driver, right? Also, if you build such driver, wouldn't
you need to test it first to see at least that it is good electrical parameters-wise before commiting to a big batch?
What kind of driver would you use for this out of your product range?
Vlad
