Kickstarter: Smart scope - Oscilliscope
0 Members and 1 Guest are viewing this topic. Read 1462 times.
Re: Kickstarter: Smart scope - Oscilliscope
« Reply #1 on: 6 Feb 2014, 07:24 pm »
Too bad the max input voltage is too low.
randytsuch
« Reply #2 on: 6 Feb 2014, 07:33 pm »
Scope probes often have a x1 or x10 switch.  Setting the probe at x10 basically divides the signal by 10, so the scope can support a voltage 10 times what it says, as long as the probe has that switch.
BobM
« Reply #3 on: 6 Feb 2014, 08:54 pm »
Neat. It was only a matter of time before someone integrated probes for a usable O'scope on a tablet app.
Folsom
« Reply #4 on: 6 Feb 2014, 09:23 pm »
I'm all about this, big time. But again almost anything I'm going to probe is going to be 110-120v.... Well not anything, but that's where I'm looking most the time when dealing with AC filtration.
The 10x probe may work well, unfortunately I'd like a scope that goes to 100-200mhz so that I can look for FM.
« Last Edit: 6 Feb 2014, 10:25 pm by Salis Audio »
randytsuch
« Reply #5 on: 6 Feb 2014, 10:08 pm »
I'll try again.
With a x10 scope probe (they are common), the voltage range will be -350V to + 350V.
http://www.digikey.com/product-detail/en/SP60B/290-1003-ND/268015
The included probe may support x1 and x10, I can't tell.
Only high voltage tube stuff would be a problem.
