sound anchor stands For Magnepans
0 Members and 1 Guest are viewing this topic. Read 1094 times.
Paddlefoot
« on: 6 Feb 2014, 12:51 pm »
i have a pair of sound anchor stand for Magnepan MMG or the MG 12..100.00 PLUS SHIPPING!
« Last Edit: 6 Feb 2014, 07:05 pm by Paddlefoot »
dpump
Re: sound anchor stands For Magnepans
« Reply #1 on: 9 Feb 2014, 03:45 am »
I wanted to let you know that the Sound Anchor stands will not fit both the MG12 and the MMG at the same time. The MG12 is wider than the MMG, so the screw holes don't line up. The 2 leg sections are the same, it is the horizontal support bar that connects the 2 sections that is a different width for each speaker. I found this out years ago when I purchased a used set from a guy who had MG12's to go on my MMG's. The horizontal bar was too wide. I had to purchase a pair of horizontal bars from Sound Anchors for MMG's to make it work. In fact, I still have the MG12 horizontal bars if someone needed them. Hope this helps.
Paddlefoot
Re: sound anchor stands For Magnepans:SOLD SOLD SOLD!!!
« Reply #2 on: 9 Feb 2014, 12:20 pm »
Thank you...they told these could be used if I wanted sell them later...I'll call them tomorrow ...thank you for the heads up...Greg
« Last Edit: 17 Feb 2014, 09:46 pm by Paddlefoot »
