0 Members and 2 Guests are viewing this topic. Read 189076 times.
I just picked my Sony up at the Post Office and will be setting it up later today. Since I am a computer dummy, is their a way to hook up a LAN cable to my Mac Mini for the transfer?
Hi Steve,If you want a direct connection fromcomputer to Z1ES, you need an EthernetCrossover Cable. This is not something that you connect to a router.Or you can connect via standard Ethernet cables via a router.
I'm guessing Cat. 6 is crossover but I'm not sure.
(Would have been nice if you knew the flash drive had a tutorial on it though!)
Most later Macs including the Mac Mini have an Auto-MDIX Ethernet interface which automatically detects and switches so that either straight-through or crossover cables can be used.Here is a list of Apple and Mac products that have Auto-MDIX:http://support.apple.com/kb/ht2274Most PCs in the last 10 years also have Auto-MDIX Ethernet, but of course there are exceptions.Steve
I did play music and it probably was not a good idea. In fact, I had the internet radio on during a good bit of the transfer. I suspect it did slow things down because my transfer took over 30 hours. I have stopped listening. My transfer is complete and the player has been "updating database" for the last couple of hours.
or alternatively this is the link with the info that is exactly the same as the flash drivehttp://docs.esupport.sony.com/homeav/Hi-Res_Audio/HAPZ1ES_guide/en/contents/TP0000221999.html - just explore the different links within it!
I suppose the better course is not to play tracks or try the remote app while the transfer is taking place.
So , Vinniie is a normal guy like the rest of us !
