0 Members and 2 Guests are viewing this topic. Read 189048 times.
I already have the app for my Itunes on my Ipad, will I need to download another app for the Sony-Ipad?
Vinnie I agree that transferring a few files at time is the way to go. I wish I had done that. I transferred everything from the folder which stores my iTunes tracks and there are many duplicates where the track is in both an ACC and AIFF format. I now wish I had cleaned up 10 albums at a time and transferred them. I have to say though, that so far this player has vastly exceeded my expectations. I am really enjoying the ability to instantly access hundreds of hi rez tracks without having to load SACD's or fool with the menus on DVD-A's. You obviously have a deep knowledge in this area (mine is limited which is probably pretty apparent by now) and I was wondering about the DSD remastering. If I am playing WAV 192 or 96.0kHZ/24 bit tracks should I turn the DSD remaster off, or just leave it on all the time?
My apologies for intruding on your Sunday. I'm confused as to why someone would pay the premium for hi rez files if regular tracks can be "remastered" to DSD on this machine, and was trying to ask if you use that feature with non-DSD hi rez files. For the future, I'll "step down" to the Sony forum with any questions. Best of luck with your machine.
Relax , enjoy the music, have a drink, light up a doobie (scratch that last one & I'll plead "a" fifth if questionedabout saying that)
Vinnie You obviously have a deep knowledge in this area (mine is limited which is probably pretty apparent by now) and I was wondering about the DSD remastering. If I am playing WAV 192 or 96.0kHZ/24 bit tracks should I turn the DSD remaster off, or just leave it on all the time?
Tom, That was you I visited ???Things sound much better now that I've stopped using equalizers. ,Unfortunately everything else is much blurrier."Those were...... The days my friend, we thought they'd never end"
BUT - if you start with a Redbook 16/44.1 file and enable the DSD remastering, you will not gain "information" (resolution) by having the Sony convert to the DSD stream. After an album has been recorded and transferred into a playback file, you can't add "more better" sound into it unless you go back to the original master and do a true remastering, which is usually done at the studio. Just like if you start out with a compressed MP3 file and convert it to a Redbook file, it still is a compressed MP3 file "riding on a redbook file format." Once you 'lossy compress' a file and data is lost, it is lost forever on that file. Vinnie
So Vinnie, you cannot up-sample 10x and play back 2x and get more info out of a CD like PS Audio is claiming?
(I'm back to sanity ,once again) The thing that has to be remembered is DSD does'nt "work" by the same principals . The objective is not to create "better" sounding PCM files. It's about formatting those "native"files to something else, to see if the reformatting to a format with some different basic sound characteristicswill affect a different sound perspective that may or may not sound better to "you"The thing is , is that we are so used to the way formats we listen to "sound", we are listening for those traits subconsciously & may want to dismiss differences as either not an improvement or barely noticeable. That's fine, that is why the feature is a defeatable choice. You don't necessarily need "more information" forsomething to sound "better" . Sometimes different is better, sometimes not, but I think you have to be willing to spend extended amounts of time listening to things in one mode or the other before you can categorically state what the process can or can't do . It make take a few weeks to decide , it may not A/B testing does'nt really work in this (or many other situations). Our " Aural Memory" is just too short & what we listen to consecutively overpowers that memory with the immediacy of what we are now hearing.You don't necessarily need to have a producer's creditials. Sound perspective is'nt something you're " locked"into.
I don't know how much more "resolution" you ever really gain when you "Upsample" or "Oversample". Yeah, you are adding "more information" but it seems to ride above the music not further into it !I don't believe double DSD sampled & up sampling are the same thing .I think this is a matter of peoplelumping all Redbook together as the "Underachieving Stepsister" of higher bit/sampled PCM.I have a pretty decent amt. of nice sounding Redbook that I am not tempted to Upsample . I would like to hear what kind of differences DSD remastering would bring to the table.I see "Resolution" as a way over used term that many feel you can reach by playing the higher numbers game.I have'nt found that to be necessarily true.
I know I'm being a "Capadoste" (Italian word for hard head that I probably misspelled)here,
I.just wish they decided to use a different term then Resolution after the file size description. I think if an abbreviation for possible (pos) were used in front of it I'd be just fine
