A Normal Network?
0 Members and 1 Guest are viewing this topic. Read 616 times.
Housteau
A Normal Network?
« on: 2 Feb 2014, 03:20 am »
I may have been misinformed, but I thought that the only way that Max 2 works with the the BDP is through a router connection.  So, that is the way I had been using it.  The other day I made a direct connection between my BDP and Mac computer and found that the Max 2 software comes up and works just fine.  Is this correct and normal?
