Specification measurements for Bryston 4bsst2?
0 Members and 1 Guest are viewing this topic. Read 904 times.
robb
« on: 1 Feb 2014, 11:26 pm »
Hi  Wondered if there is a place on the Bryston website or elsewhere where the specification for channel separation is listed.  While I currently have the 4bsst2 in my system, I would like the measurements in case I wanted to compare them with other amplifiers.
Perhaps James or somebody could direct me to the proper place?
Rob
  • The Demo is Everything!
    • http://www.bryston.com
Re: Specification measurements for Bryston 4bsst2?
« Reply #1 on: 2 Feb 2014, 12:35 am »
Rob
Hi Rob
I will see but the Bryston amp channels are totally independent within the chassis so there are no common components.
james
robb
« Reply #2 on: 2 Feb 2014, 01:54 am »
James.
I would appreciate that measurement.  I have found that the crosstalk and channel separation measurements seems to vary quite a bit among amplifier manufactures, with some very expensive amplifiers showing measurements similar to a cartridge. My  Bryston creates  a  wide, deep and stable soundstage, so I would imagine it has excellent measurements in this area.
Thanks for any info
Rob
