WTB: Bent Audio Tap-X
0 Members and 1 Guest are viewing this topic. Read 746 times.
PaulFolbrecht
« on: 1 Feb 2014, 10:33 pm »
I'm not sure if this came in both AVC and TVC versions but I need 6 dB of gain so it has to be TVC.
John Chapman
    • http://www.bentaudio.com
Re: WTB: Bent Audio Tap-X
« Reply #1 on: 4 Feb 2014, 12:50 am »
Hello!
Just stumbled onto this and thought I'd pass on a quick note. Both units can potentially give you some gain - +6db gain was optionally implemented on older TVC units (depending on the build) and it is always included as part of the design on  TAP-X (and AVC-1) units - both of which use the AVC's in them.
Most of the older TVC based units had a manual switch to kick gain up 6db. The newer AVC based units seamlessly start adding gain as you turn the volume up past unity gain - up to a max gain of +7db. I wanted them to be 'one louder'.......
Thansk!
John
