BR2 Remote Control - Best Option?
0 Members and 1 Guest are viewing this topic. Read 2038 times.
Oswego0522
« on: 31 Jan 2014, 05:19 pm »
I have the following Bryston equipment: BDA2, BDP2, BP17, 4BBST2.
Is the BR2 remote control the best solution for remote volume control or are there other options that I should consider? Was hoping that an app existed to do so.
I have a Logitech Harmony 900 remote, but was unable to successfully program it to control my PB17. Not sure if done correctly whether the Harmony can control the BP17?
Grit
  • - Garrett
Re: BR2 Remote Control - Best Option?
« Reply #1 on: 31 Jan 2014, 06:54 pm »
Does it have a learning option? The IR codes exist, but may not be included in the Harmony software. Can you import IR codes in Harmony?
Oswego0522
« Reply #2 on: 31 Jan 2014, 11:36 pm »
I'll have to log back into Logitech's webpage on which I can configure this remote. To date, I have only worked with their pre-existing options and do not recall seeing an option by which I could import IR codes. I'll check this evening.
unincognito
    • bryston.com
« Reply #3 on: 4 Feb 2014, 02:21 am »
They may not have a bp17 listing and I believe they have if code for some products and I believe the bp-17 uses the same it codes for volume as the bp-16, b135 and b100.
Cheers
Chris
Oswego0522
« Reply #4 on: 4 Feb 2014, 03:59 pm »
Thanks for the feedback.
I will try using the codes for the other devices that you mentioned, Chris.
If that fails, I will order the BR2.
Oswego0522
« Reply #5 on: 6 Feb 2014, 04:41 am »
Success :)
I was able to program my Harmony One remote to control the volume on my BP-17 by entering BP-16 as the device to be controlled.
