BUC-1 usb power?
0 Members and 1 Guest are viewing this topic. Read 879 times.
ltddrop
BUC-1 usb power?
« on: 29 Jan 2014, 04:57 pm »
Does this unit use usb power for anything at all?  i.e. can a usb cable with no power be used?  Thanks
  • The Demo is Everything!
    • http://www.bryston.com
Re: BUC-1 usb power?
« Reply #1 on: 29 Jan 2014, 05:24 pm »
Hi
It only uses the USB power to detect that a USB cable is being used.
james
ltddrop
« Reply #2 on: 29 Jan 2014, 07:55 pm »
So would it be ok to run a cable with no power?  Would the usb light not illuminate?  Thanks
« Reply #3 on: 29 Jan 2014, 08:02 pm »
No you you need a powered cable otherwise the BDA will not detect the connection.  But the BDA is not using the power from the USB cable to process the signal it has its own internal independent analog and digital power supply.
james
