New Copper Khartago-Kismet and Candela on the way
0 Members and 1 Guest are viewing this topic. Read 4016 times.
newzooreview
« on: 28 Jan 2014, 12:42 am »
It looks like the day for updates on new Odyssey goodies in incubation. Klaus sent me the photo below from the nursery. A healthy complexion! Due date is on the near horizon, I believe.
aaron.luebke
Re: New Copper Khartago-Kismet and Candela on the way
« Reply #1 on: 28 Jan 2014, 12:59 am »
Better call Klaus - he put the knobs on the top  :o...again.   :duh:
JK.... :thumb:
newzooreview
« Reply #2 on: 28 Jan 2014, 01:12 am »
JK.... :thumb:
Klaus says the kismet knows its destiny, so the knobs are more for decoration.
Chops
« Reply #3 on: 28 Jan 2014, 03:13 am »
That copper is beautiful. I might have to see if it's available for my amp when I call Klaus in a couple days with my voltage readings.  :green:
srwilsonmiami
Inexpensive and simple device to take voltage reading needed
« Reply #4 on: 28 Mar 2016, 11:08 pm »
Klaus has asked me to measure the voltage at my ac outlets in my listening room before he builds my amp. Would something like a Kill A Watt meter do the trick? I see they are around $20.
GentleBender
« Reply #5 on: 28 Mar 2016, 11:32 pm »
You just need a multimeter like this. http://smile.amazon.com/Mastech-MS8268-MS8261-Digital-Multimeter/dp/B000JQ4O2U?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o05_s00. This is the exact one I used for the same purpose last year.
srwilsonmiami
« Reply #6 on: 29 Mar 2016, 03:09 pm »
Thanks for the info. Is that complete or do I need leads as well?
GentleBender
« Reply #7 on: 29 Mar 2016, 03:38 pm »
Totally complete, even batteries. Just make sure you remove the protective plastic covers from the leads so that they fit into the receptacle. When mine arrived I thought I needed other leads until I discovered the plastic covers are removable.  :duh:
srwilsonmiami
« Reply #8 on: 1 Apr 2016, 08:18 pm »
Ok great, will order one for my toolkit.
