0 Members and 1 Guest are viewing this topic. Read 22379 times.
Do you guys agree with this statement?
It's impossible for any speaker to radiate in such a way as to avoid room acoustics problems. That would be called headphones. Once sound gets into the room, it bounces around creating peaks, nulls, flutter echo, early reflections, modal ringing, and reverb in larger rooms. There is no avoiding this. So in order of importance:1) The room2) The speakers3) Everything else--Ethan
Nothing is more important than the room unless one designs a speaker to eliminate room interference. Placement in the room is just as important. Both room acoustics and placement are key. One compliments the other. One can if dedicated enough can design the room around the dispersion characteristics of said speaker. That's my take on it. charles
How the Speakers interact with the room is far more important than anything else in the chain.A bad room can make great speakers sound bad, and bad speakers in a great room is pretty much a waste of time. You can treat a bad room and make it sound better, but there is very little you can do to make bad speakers sound good.Saying that the room is always more important than the speakers, or vice-versa, can only be a generality and not correct all the time. Just make sure you take both ends of the equation into consideration when planning or seeking the best possible sound.
Those speakers are not very attractive... neither are a ton of acoustic panels.
