0 Members and 1 Guest are viewing this topic. Read 15882 times.
I'm guessing it's a network issue. Is the Oppo connected via a wireless router? I'm not familiar with the Oppo but if possible connect your Oppo with an ethernet cable to your router and see if that helps.
I have been wondering about this from a wider perspective lately. Physical media is going away (e.g. Blockbuster video stores are closing, demise of Bluray in the news). So the dependency on streaming video will increase. And the content provider model is shifting too with original content coming from Netflix. Bottom line more content will be streamed. And with the current distribution it is already clogged, so you get crappy resolution that kenreau is experiencing. What will change to remedy this?Then to make matters worse, TV sizes are inflating to the unimaginable 10 years ago, and now at very high resolutions (4K and Ultra HD). So now we will be able to see all the macroblocking in mega 12 inch bit chunks on the screen! I am curious how this will flush out. I have an old 1080P Sony LCD TV @ 40" and recently picked up a Chromecast dongle to watch Netflix streamed content, with minimal hardware setup connection hassle. Even with High Speed cable (@47mbps tested last night), I get some macroblocking which seems to be network congestion. if I were in a household with a couple of kids accessing the same bandwidth, I would imagine it would be worse, but I am the only one using my connection. For the most part, when the streamed content is HD, the video quality is fine, but not great. That also applies to streaming nexflix to a retina display iPad.Keep the round discs or come up with another cheaper, more durable replacement!
Check router for firmware updates. Check to make sure modem and router have room to breath. I've pulled blankets off of them, and even routers off of overheated modems.Something overlooked constantly... If you have cable make sure all the connections with actual cable are wrench tight, with a wrench. It can make a HUGE difference in performance; even when it seems fine.
Sadly there is a lot of possibilities
My personal experience lately is that the problem is with Netflix.
