0 Members and 1 Guest are viewing this topic. Read 7318 times.
Try taking the preamp to another ac outlet in a different room and set it up temporarily the same way. I have heard cases where the Ac Line may have a loose ground wire at the Electrical Panel. Also shut the power off on the " Noisy " outlet and check to see if you have a loose or bad wire on the Ac outlet wire. Sometimes the wire over time can crack or even break where it is wrapped around the Outlet terminal. Also take the cover off the Tempest, where it enters and check the IEC connection......Hope you get lucky and find something loose....
While your at it upgrade your outlet if you haven't already. The outlet has a very real effect on sound.
I have heard rumors, that some tubes don't work well with Rogue equip.Have you tried different tubes ?
Yah Tom : My reply for changing rooms was to use another circuit to see if the Hum is present on another line Outlet . You could be dealing with many different issues and I would try to eliminate the issues from the Electrical Panel forward......If you can temporarily set up your system in another room , it will at least tell you if the plug/s ( outlet or line ) in your normal listening room is the problem. If the Hum persists in your temporary set up room, than you can rule out Hum coming from Listening room Outlet or Line from the Panel....
Does it still hum when you mute your 99? If so, turn off amp, disconnect amp from pre, install shorting plugs to amps inputs and try unplugging all the upstream components one at a time (while amp is on). This sounds crazy I know since these components you're unplugging aren't even hooked up to the amp but it does eliminate the possibility of your amp picking up stray emf from the other components (a problem I had a while back). I also once had some hum in an amp that went away when I plugged the amp into a power conditioner.Did you try cheaters on all but one component?
To be clear, are we talking about a chassis hum? If it is coming from the amp, may be DC on the line. AVA's Humdinger could help with that (and there is a return option if it doesn't work). Or hum through your speakers? If speakers, what kind of speakers do you have and how efficient are they? Tube amps aren't always dead quiet through speakers, particularly if the speakers have an efficiency of 90dB or above.
