Audio Space Galaxy 88 Tube Integrated
0 Members and 1 Guest are viewing this topic. Read 2348 times.
diofan56
« on: 20 Jan 2014, 09:39 pm »
Audio Space Galaxy 88 integrated.  Includes remote control, manual, and original packaging.  Weighs approximately 50 pounds.  Excellent condition.
Read the review at:
http://www.stereomojo.com/AudioSpaceGalaxy88integratedtubeamplifierreview.htm
Specifications from the manual:
Input Impedance:  >89k ohms (RCS/Direct In)
Output Impedance:  4 and 8 ohms
Output Power:  24W x 2 (Triode class AB Push-Pull), 48W x 2 (Ultralinear Class AB Push-Pull)
Damping Factor:  > 5
Frequency Response:  20Hz – 30KHz -1dB
T.H.D.:  < 1% 20Hz – 20KHz (Ref. Output)
Total Gain: 30 dB
Input Sensitivity:  300mV – 600mV
S/N Ratio:  >80dB (Hum Noise < 3mV)
Channel Balance:  < 1dB 20Hz - 20KHz (Max. Volume)
Channel Separation:  > 60dB (1KHz - 3.3KHz)
Vacuum Tubes:  V1, V2, V3, V4: KT88 (6550) x 4 -- V5, V6: 6N8P (6SN7) x 2 -- V7, V8: 6N9P (6SL7) x 2
Power Requirement:  AC – 120V +/- 5% 50/60Hz
Dimensions   :  330mm x 400mm x 190mm (D x W x H)
Weight:  22.5kg (Net Weight)/ 26.2 kg (Gross Weight)
Check out my eBay feedback under lambdav1 and AudiogoN feedback under diofan56.
The price of $1200.00 includes PayPal fees and shipping within the continental United States.
The first person to get the money to me gets the item.
