FS/Trade? Rotel RMB-1095 5-channel power amplifier (200wpc)
0 Members and 1 Guest are viewing this topic. Read 1199 times.
jephdood
!!!!!!SOLD!!!!!!
$950.  Located in Auburn, WA.
The amp is in great shape. Black chassis/fins with silver middle front plate. RCA and balanced/XLR connections. TWO massive torroidial transformers inside. HEAVY (@75 lbs).
I'm not the original owner, so I can't tell you exactly how old it is. In my care it's been babied. Also took in recently to Desco Electonics (authorized Rotel service dept) where it was given a clean bill of health. I like to make sure on things before selling for peace of mind.
Selling to downsize a bit. Otherwise, this wouldn't be going anywhere.
The price is FIRM. MSRP on this amp was (I think) $2,100. They just don't show up all that often. Rarely, in fact. Also, no delivery, no shipping, and no payments other than cash. *MAY* consider partial trade for a sub. Current version SVS Plus or maybe a slightly older Ultra if in good condition. Or, maybe a 20-39pci sub to match the one I already have. Rythmik HP? Hsu 15? Possibly. Those are the ONLY things I would consider trading for.
Will get around to taking some pics later in the day.
Here's the product pitch and specs from Rotel's website:
Producing a full kilowatt (1000 watts!) of output power, Rotel's RMB-1095 is a stunning realization of Rotel's capabilities in amplifier design. It is, for all intents and purposes, a multi-channel version of the RB-1080 stereo power amplifier, already recognized as one of the finest amplifiers available at any price from any manufacturer. Rated at 200 watts per channel (all 5 channels driven into 8 ohms, 20 Hz 20 kHz, less than 0.03% THD), the RMB-1095's power supply is built around two 1.2 kVA toroid transformers. Eight 15,000 uf British-made BHC slit foil capacitors provide prodigious storage capacity and combine with 30 150 watt/15 amp output devices for uncompressed reproduction of the most dynamic source material. A sophisticated "over current" protection circuit with front panel LED indicators guards against potentially harmful operating conditions. Special "current absorbers" minimize turn-on surges while gold plated balanced XLR and single-ended RCA inputs provide easy connection to a variety of controller/preamplifiers. Heavy rear casters assist in placing the amplifier.
Model RMB-1095
Continuous Power Output (20-20 kHz, <0.03%) 5x200 watts /ch / 8 ohms
DIN Power Output (1 kHz, 1%) 5x330 watts /ch / 4 ohms
Total Harmonic Distortion (20 Hz - 20 kHz, 8 ohms) <0.03%
Intermodulation Distortion (60 Hz: 7 kHz, 4:1) <0.03%
Frequency Response 15Hz - 100kHz +0.5dB, -3dB
Signal to Noise Ratio(IHF A) 116dB
Power Consumption 800 watts
Dimensions (W x H x D) mm 432 x 237 x 410 mm
Dimensions (W x H x D) in 17 1/8 x 9 3/8 x 16 1/8 in
Front Panel Height 221 mm, 8 11/16 in
Weight (net) 34 kg, 75 lbs
Review: http://www.audioholics.com/amplifier-reviews/rotel-rmb-1095
Thanks for looking!
« Last Edit: 23 Jan 2014, 04:34 am by jephdood »
jriggy
Re: FS/Trade? Rotel RMB-1095 5-channel power amplifier (200wpc)
« Reply #1 on: 21 Jan 2014, 07:04 pm »
Are you saying this amp is available for a local pick-up sale only??? If so, where would that be?
jephdood
« Reply #2 on: 21 Jan 2014, 08:14 pm »
Oops.  Didn't realize my profile didn't have my location in it.  Sorry.  One of my pet peeves too.   :duh:
Edited my OP.
