Price Reduced: The Truth pre by Ed Schilling - Sold
0 Members and 1 Guest are viewing this topic. Read 2802 times.
genjamon
« on: 19 Jan 2014, 03:57 pm »
I will ad pics to this listing later, but wanted to get it posted.
I've had this unit for several years. It was one of Ed's earlier versions, but was sent back this year to be checked out and brought up to current generation. He made  few small changes, and finished the case with black fascia and silver casing.
For this unfamiliar, this is an active (not passive) unity buffer with volume control.  As per Ed, it has a vanishingly low output impedance, so can drive anything, and I have personal experience with his other claim that it really reduces the impacts of different interconnects from Truth to amp because of this.  It also has a very very high input impedance (around a million ohm or something), so any source should be able to drive it easily.
Volume control is also very innovative.  Uses photo resistors to modulate gain on the active buffers. I'm not extremely clear on how this differs from the various optocoupler passive pre's available, but Ed claims they're not the same thing at all, and that the Truth has a completely linear impedance response with respect to frequency and that most of the optocouplers vary quite a lot with frequency.  Something like that.
All this can be found in posts on Ed's forum for his company Horn Shoppe.
This unit has three inputs and two outputs. Input switching on the rear. Volume control and l/r balance control on the front. Has a captive 6 ft power cord, but Ed could easily swap out for an IEC inlet if you wanted. I never felt the need, and was glad to avoid yet another expensive after market power cord in the system.
Fit and finish is pretty DIY, but decent as long as you're not admiring from short distances.
« Last Edit: 6 Feb 2014, 05:02 pm by genjamon »
playntheblues
  • D-Sonic, Mola Mola TamBagui, Tekton DISE
Re: FS: The Truth pre by Ed Schilling - $600 obo
« Reply #1 on: 19 Jan 2014, 04:58 pm »
How many db of gain and is it remote?
genjamon
« Reply #2 on: 19 Jan 2014, 06:19 pm »
No remote, and it's a buffer based pre, so max is unity gain. The volume control is not in the signal path and only adjusts the gain of the buffer circuit from a fraction of full output to full output. Think of it as like a passive pre, but without the disadvantages of needing to pay close attention to impedance matching.  It has tremendous drive compared to other passives I have tried.
genjamon
« Reply #3 on: 23 Jan 2014, 04:26 pm »
Here are some pics.  The original chassis was pretty cheap looking brushed aluminum.  Ed has offered some coatings for chassis to spruce them up a bit, so I sent it to him a while back for this service.  I went black with the fascia and silver for the rest.  It's not the highest quality coating, but looks decent at listening distance.  The black front is kind of a texturized finish, and the silver body is a pretty smooth finish.  The texturized black has come off around the edges just a bit, and I tried to show that in the picture taken from above.  It's only visible if you're standing over the unit or inspecting closely, but you should be aware of it.  I'm sure this could be touched up.
These are somewhat DIY looking units, but sound quality is very very high and transparent for the price.  I found it more detailed and clear than the Dodd buffer in a shootout, and not in a harsh, "transparent" way.  If you don't need extra gain, which most of us don't, this is going to be an excellent unit for the price.  I had to go to a $4K preamp (used price) to do significantly better.
genjamon
Re: Price Reduced: The Truth pre by Ed Schilling - $550 obo
« Reply #4 on: 31 Jan 2014, 03:26 pm »
bump for price reduction - $550 plus shipping
sonicxtc
« Reply #5 on: 5 Feb 2014, 05:25 am »
PM Sent with intent to purchase.
genjamon
« Reply #6 on: 6 Feb 2014, 05:01 pm »
Sold
