Is there a way to get an audio only file from a DVD?
0 Members and 1 Guest are viewing this topic. Read 877 times.
fado
RE: Korean Drama "Thank You"
The only original soundtrack CD I can find is $50.00 US whereas DVD's are available used for less than $20.00. Is there any way to get portions of the soundtrack as an audio file (MP-3, WAV, FLAC, etc) from the DVD?
Thank You
rbbert
Re: Is there a way to get an audio only file from a DVD?
« Reply #1 on: 18 Jan 2014, 04:11 am »
DVD Audio Extractor is one program commercially available, and some Internet searching might uncover something free which would also work.
Austin08
« Reply #2 on: 18 Jan 2014, 04:36 am »
+1.
 I have been using sometime and it is very easy to use.
fado
« Reply #3 on: 18 Jan 2014, 05:57 pm »
Thank You rbbert & Austin08. I will download the DVD Audio Extractor 30 day free trial after I get the DVD and give it a try.
