Looking for a A/V-3S x-over pic
0 Members and 1 Guest are viewing this topic. Read 1419 times.
Scott Trebble
« on: 17 Jan 2014, 08:34 pm »
Like the subject line says...  I'm looking for a pic of a crossover for a A/V-3S (center speaker)
I've found pics for the A/V-3 towers, which split the woofer/tweeter circuits on to 2 of the braces, but I've also found the post where Danny says he puts the whole circuit on a board that slides into a woofer hole on the 3S.  That's what I'd like to do.
Thanks for any help you can give  :D
Cheers,  Scott
Scott Trebble
Re: Looking for a A/V-3S x-over pic
« Reply #1 on: 24 Jan 2014, 05:24 pm »
No one can help me out with this?  :(
When it comes to the woodworking,  I'm all good.  But I just don't seem to have the aptitude for the electronics.
The diagrams are clear enough,  it just eludes me how to put it all together.  :scratch:
A picture or diagram showing the physical layout would be so much appreciated.
Thanks again for any help you may have,
Cheers,  Scott
Danny Richie
« Reply #2 on: 24 Jan 2014, 05:27 pm »
Cheers,  Scott
Scott, I looked around and did not have a pic of the crossover assembled.
I have a diagram for the A/V-3S in picture form though. Shoot me over an e-mail and I'll forward it over to you.
Scott Trebble
« Reply #3 on: 30 Jan 2014, 07:09 pm »
   OK, so I'm still trying to wrap my head around the layout for the board for the A/V-3S x-over  :scratch:
I thought maybe I would start out with the x-overs for the surrounds,  as they looked simpler.  I found a pic of these in the crossover 101 thread, and copied the layout that Ron had used (thanks Ron  :)).  At least that gave me a start.  Here's what I came up with :
The wiring looks a bit different than Ron's',  but I believe it is correct...  another view:
I'd appreciate it if someone could verify that it won't blow up on me  :D
I sized it to fit nicely on the bottom of the cabinet.
I would still like to see a pic of the physical layout of the board for a A/V-3S.  The pictograph diagrams just seem to confuse me.
I'm still hoping someone can help me out.   :?
Cheers,  Scott
Danny Richie
« Reply #4 on: 30 Jan 2014, 07:46 pm »
Yep, that looks good.
Scott Trebble
« Reply #5 on: 2 Feb 2014, 06:38 pm »
OK,  I finally just bit the bullet, and came up with this :
Hopefully, the wiring is correct  :?
The reason for the odd shape is this allows the finished board to go through the tweeter opening when the front baffle is attached.
It's a bit of a squeeze but just makes it.
It fits nicely between the two baffles behind the tweeter, with minimal interference to the internal (I think  :))
Is there any reason not to use this same setup on the A/V-3 towers ?  Like this:
I'm happy to finally have gotten over this hurdle (I hope)
What a painful process it's been!
I'm looking forward to moving on.
Thanks for your help Danny  :)
Cheers,  Scott
Danny Richie
« Reply #6 on: 2 Feb 2014, 06:58 pm »
That looks good.   :thumb:
