New MPOD version setback?
0 Members and 1 Guest are viewing this topic. Read 975 times.
Marius
« on: 16 Jan 2014, 11:11 am »
HI,
Did anyone of you experience the same setback using the new Mpod as I did:
- no more indication of resolution on playing track
- no more album view available, only the mall icon bottom right corner.
- 'now playing' is buried much deeper in the interface
- several connection issues making it hard to find the correct BPD (Ive had 2 displayed, one manually configured, one discovered)
- no more feedback when updating the db, no clue if the command is actually working.
All n all, I wish I hadn't updated automatically.... I'm using MM latest firmware beta version, maybe that doesn't really work well with the MPOD software yet, but I can't go back to try, so thought I'd ask you fellow users.
Marius
gil99
Re: New MPOD version setback?
« Reply #1 on: 16 Jan 2014, 04:04 pm »
Hi,
I don't have the beta software on my BDP-1 and I have the same issue.  I also wish that I could go back to the older version.
Gil
alexone
« Reply #2 on: 16 Jan 2014, 04:24 pm »
...yes, the new mpod version is a step back :(.
sad but true.
al.
