Inexpensive DAC suggestions?
0 Members and 1 Guest are viewing this topic. Read 4600 times.
scott_man
« on: 13 Jan 2014, 11:16 pm »
I would like to connect an AppleTV via a DAC to a small bedroom system.  I need a DAC with a toslink connection.  Are used DACs in the $200-300 price range significantly better than the little $40 boxes on eBay and monoprice?  Any suggestions or recommendations.   Budget is $250 or less.
Thanks. Scott
geowak
Re: Inexpensive DAC suggestions?
« Reply #1 on: 13 Jan 2014, 11:31 pm »
You could look for a used Schiit Audio Bifrost. If you like it, you can upgrade to the Loki and get DSD for about $150. That would sound really fine. My two cents...
srb
« Reply #2 on: 14 Jan 2014, 12:01 am »
The Loki only has a USB input, so it won't work with an Apple TV.
rpf
« Reply #3 on: 14 Jan 2014, 03:27 am »
And Apple TV doesn't do Hi-Rez audio, IIRC.
A used Bi-Frost or used Micromega MyDac (which I own, like and am soon going to connect to an Apple TV) would work well and greatly improve the sound.
Folsom
« Reply #4 on: 14 Jan 2014, 05:00 pm »
The answer is no. But it depends on power supply quality.
My go to for super cheap, super musical, is any chinese 1543 DAC on ebay, battery powered, maybe with a cap swap on output and on battery power (with a few caps across the lines).
I've never heard anything remotely as easy to listen to at a price sub $1k or so. Sure some of them do neat tricks, but I don't leave them on long. It just works for non-critical listening so well, even a dance party, that I always suggest it non-audiophiles as a way to not have such gruelingly harsh music (and get some real bass).
« Reply #6 on: 20 Jan 2014, 11:08 pm »
Get a Grant Fidelity DAC-11.  Swap out the 6922 tube for an Amprex early 1960's 6DJ8 non A frame tube and you will have a nice non fatiguing tube sound.  I have one and it sounds great in my second system with a Class D audio amp and MMG speakers.
http://shop.grantfidelity.com/Grant-Fidelity-TubeDAC-11-D-A-Converter.html
This DAC has had some good reviews-
I'll second the GF TD 11.  I'm also using one  and am using a '63 Amperex 6DJ8 as well.  I've also replaced the power cord with a Pangea AC14SE.  I love this dad , especially at its price point
-jay
avta
« Reply #7 on: 21 Jan 2014, 12:47 am »
+1 for the Micromega Mydac. I've got one and like it. All connections you want. Got mine at Music Direct (http://www.musicdirect.com/p-106045-micromega-mydac-asynchronous-usb-dac.aspx ) $369
Letitroll98
  • Too loud is just right
« Reply #8 on: 21 Jan 2014, 12:39 pm »
Unlike some of the above suggestions, the Audio gd NFB-11.32 is only slightly above your price point at $299.  Equipped with a 32bit / 384K Asynchronous Transfer USB-32 Chip
and a 32bit / 192K Sabre ES9018 DAC chip, and of course includes the optical input you require.
http://www.audio-gd.com/Pro/Headphoneamp/NFB1132/NFB11.32EN.htm
raysracing
« Reply #9 on: 21 Jan 2014, 01:18 pm »
delete
mick wolfe
« Reply #10 on: 21 Jan 2014, 04:07 pm »
-jay
I have 2 GF TD 11's. One for casual listening / Pandora 1 in my family room and a Bolder modded unit in my listening room. Very versatile, excellent sounding DAC's. Stock tubes in both replaced with Ei Elite( gold pin) 6DJ8's.
I.Greyhound Fan
« Reply #11 on: 21 Jan 2014, 05:38 pm »
Check out the sale price of this Simaudio Moon DAC and read the review
http://www.musicdirect.com/p-15063-simaudio-moon-100d-dac.aspx?source=igodigital&
mcgsxr
« Reply #12 on: 21 Jan 2014, 06:27 pm »
Interesting piece.  Explains the ones I have seen floating around for $400 up here in Canada.
