Converting US 4BSST2 to Work in China
0 Members and 1 Guest are viewing this topic. Read 1471 times.
budcook
« on: 12 Jan 2014, 05:15 am »
I'm selling my 4BSST2 and someone asked if it could be converted to work in China.  The build date is 1310.  The amp is in the US and operates on 110 V. The required voltage in China is 220V.
I looked at the schematic on the Bryston website and it looks like the transformer can handle multiple voltages.  Does anyone know the answer?
Bud
« Last Edit: 12 Jan 2014, 01:13 pm by budcook »
Elizabeth
Re: Converting US 4BSST2 to Work in China
« Reply #1 on: 12 Jan 2014, 12:20 pm »
Googling China the voltage is 220 volts.
budcook
« Reply #2 on: 12 Jan 2014, 12:53 pm »
Thanks Elizabeth, I should have said that.
Bud
PRELUDE
« Reply #3 on: 12 Jan 2014, 01:07 pm »
I'm selling my 4BSST2 and someone asked if it could be converted to work in China.  The build date is 1310.  The required voltage is 220V.
Bud
Where are you located and what is the voltage you use?
budcook
« Reply #4 on: 12 Jan 2014, 01:11 pm »
I'm in the US.  Again I omitted an important detail.
Bud
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #5 on: 12 Jan 2014, 01:45 pm »
Bud
Hi Bud
It would be converted by our China distributor as they know all the safety issues and have the correct hydro stickers and would re-register the warranty.
james
budcook
« Reply #6 on: 12 Jan 2014, 01:50 pm »
Hi Bud
james
Thank you James.
Bud
