0 Members and 1 Guest are viewing this topic. Read 2820 times.
DannyHow bad is it going to be if I plug up the ports on the LS-C? I know there is a design for a sealed cabinet but the LS6's I purchased came with a bare MDF cabinet built by Ruben.I really dont have a ton of room to pull the center out away from my screen. The 6's are closer than I would like but have got them sounding pretty dang good so far with little tweeking.
Thanks DannyNo need to try and retune the ports, just looking to push it as close to the wall as I can.would you seal the ports( foam port plugs) or just leave them open and push it toward the wall? Screen wall is 4" thick of sound insulation
good to see you working on that LS-C ! i had that baby sitting around for months and never had the chance to think of how to work it.
Sorry to drag this a little off topic, but if one were building a cabinet from scratch and wanted to go with a sealed design how much smaller should the cabinet be?
You can drop the depth about an inch or so. I would cut too much away though.
I think you mean "I would not cut too much away though".
I was able to puzzle it out. I was assuming that a sealed box should be smaller. Would it be better to just use the regular size box and just build it without ports? Or make it larger?
