Blueshift Bluetooth Speaker Powerd By Super Caps...not Batteries
0 Members and 1 Guest are viewing this topic. Read 1574 times.
rodge827
Hi All,
*I hope I posted this in the right place, if not would the facilitator move this post to the proper Circle.*
Well the title says it all.
There is a small very small company producing  this rather unique Bluetooh speaker.
The driver is a 4" Fostex with a small digital amp powered by Super Capacitors wrapped in a bamboo enclosure.
The caps give you up to 6 hours of play time and recharge in about 5mins and can go through 500,000 cycles!
Actually it's 500,000 -1,000,000 cycles or recharge.
There is more info out there about this so do a search.
Super cap technology is the wave of the future...very cool. 8)
http://blueshiftpdx.com/
jeffh
That is an interesting product! Wonder which Fostex they are using?  Looks like the
Fostex FE103En.
viggen
Hornshoppe Horns uses the same drivers and with enclosure and close to wall placement you MIGHT get something in the 50hz range.  The BS's 100hz and under might be utterly inaudible?
rodge827
