For sale: Wright Audio Lolita SET, 950.00
0 Members and 1 Guest are viewing this topic. Read 1646 times.
cooch
« on: 8 Jan 2014, 12:53 pm »
Great sounding integrated made in USA. SET magic at its best. I am original owner and unit is in excellent condition, about 1 year old. thanks
Tube complement: (2) 6N1P; (1) GZ34 / 5AR4; (2) KT77, E34L, EL34 or EL34B connected in triode mode. Aluminum sided version supplied with JJ KT77 output tubes. 7 watts per channel output.
Controls: Power, Inputs A and B switch, Stereo Volume, Left Channel and Right Channel Level Presets.
2 inputs. Accommodates all standard line-level sources.
Tube power supply with choke filtering, for highest resolution and most pure sound. Also provides slower warm-up for longer parts life.
Separate left and right channel preamplifier / driver tube power supply capacitors for enhanced channel separation and sonic imaging.
8 ohms speaker output.
Gold - plated jacks and heavy duty, 30 amp - rated, 5 - way binding posts which accept banana plugs.
Detachable IEC power cable.
RoHS compliant parts used where applicable.
Externally mounted fuse.
All point - to - point wiring. Non-obsolescent construction. No circuit boards for ease of installation of future upgrades.
Glossy, black-anodized aluminum with one-eighth inch thick top plate for minimum electrical and mechanical interference providing quiet operation.
Size: Compact 12 x 11 3/4 x 8 1/2"
Net Weight: 24 lbs.
Designed and assembled in the U.S.A. using U.S. and Global components.
Syrah
Re: For sale: Wright Audio Lolita SET, 950.00
« Reply #1 on: 30 Sep 2015, 09:36 pm »
Is this still for sale?
