**SOLD** FS Hegel H100 Integrated SS Amp with built-in USB DAC ($1699)
0 Members and 1 Guest are viewing this topic. Read 2038 times.
mtruong34
**REDUCED** from 1899
Silver, mint condition except for two very tiny nicks on the rear edge of the amp. Everything else looks perfect.
Original box, manual, power cord and metal remote control.
Technical Details
Output power: 120W + 120W in 8 ohms, 220W + 220W in 4 ohms
Volume, Input source and mute controlled by Hegel RC2 remote
Inputs: 4 Unbalanced (RCA), balanced (XLR) and USB
Home Theatre input: maximum level power amp input (RCA)
2 pcs Pre Out (RCA), 1 pcs Recording output (RCA)
Speaker outputs: One pair of heavy duty gold plated terminals
USB resolution: 16 bit / 48 kHz, Plug & Play. No drivers needed
Input impedance: Balanced 50kohm, unbalanced 11kohm
Analog frequency resp: Less than +/- 0.2 dB deviation 20Hz-20kHz
Signal to noise ratio: More than 100dB
Crosstalk: Less than -100dB
Distortion: Less than 0.005 % at 50W i 8 ohm
Intermodulation: Less than 0.01 % (19kHz + 20kHz)
Damping factor: More than 1000
Power Supply: 630VA, 67 000uF capacitors
Output stage: 8 pcs 15A 150W high speed bipolar transistors
Power consumption: 30W in standby switched on
Dimensions/weight (ex feet) : 10cm x 43cm x 42,5cm (HxWxD), weight 16kg
Dimensions/weight US (ex feet): 4" x 17" x 16,7" (HxBxD), weight 35,2 lbs
I travel extensively overseas for work and must sell-off a bunch of gear that I can't take with me.
Item is located in Houston, TX
Asking $1899 + shipping/insurance + PP fees (unless gift option used)
I have perfect feedback under same username on ebay and audiogon
Please Note: Amp was originally 230VAC but was converted for US voltage 120VAC by the authorized dealer in Singapore. Lowered asking price reflects this.
« Last Edit: 18 Feb 2014, 10:33 pm by mtruong34 »
mtruong34
Bump
mtruong34
Bump for price reduction
