FS: Ayon Triton II Integrated
0 Members and 1 Guest are viewing this topic. Read 5096 times.
jriggy
« on: 7 Jan 2014, 07:05 pm »
The Triton II utilizes 8- Shuguang Black Treasure KT-88 power tubes, 6-12au7 NOS preamp tubes. Auto Bias circuitry. Monster, top quality, fully potted huge transformers. Run it as an integrated, preamp, or dedicated amp...
This amp is transparent, powerful, musical, and very dynamic. 125 watts in Pentode, or 80 watts in Triode, no negative feedback, pure Class A, from this dead quiet 95 pound amp. There are a couple great reviews for the Triton on Enjoy The Music and Positive Feedback. The Triton II is definitely an upgrade, as I owned both. Ask for details if interested.
I am the original owner, purchased from authorized dealer 2 and a half years ago. It has performed flawlessly, is in beautiful condition and truly is dead quiet --with whatever I hooked it up with. I estimate, from my regularly scheduled listening days that the tubes have around 2000 hours use. I will give it an 8 on the Agon scale due to some faint surface dust scratches on the chrome transformer covers. Im sure some polish would remove these faint lines. Although it is probably ok at a 9 rating too! 100% feedback on Agon as Jriggy
Asking $5500 + shipping (from 46220)
Please PM with any and all questions
Sorry for the grainy low light pics. I can try for better if one needs.
Here is a c&p list of Specs and features:
Features-
Full-featured vacuum tube stereo integrated amplifier
Switchable between Pentode and Triode mode
Timer warm up circuit for all tubes, extends tube life
Dual choke filtered power supply for ( KT88 )
Single choke for pre and driver stage (12AU7)
Automatic power tube protection circuit system
0dB Negative feedback
2 separate power transformers (anode - high voltage and filament - low voltage)
Power transformers are encased, excellent damped and RFI/EMI shielded
Innovative power supply provides a high speed energy delivery on transients
High performance & efficiency output transformer
All transformers are sealed with an anti-resonance compound material
Selected, premium quality passive components used in all applications
High speed capacitors
Shortest possible signal paths
Gold-plated industrial grade PCB
Teflon isolated - internal wiring
Ground switch
Mute function - RC
Silver matrix - internal signal cable
Central one-point star earth grounding
Auto bias adjustment – rear panel
Fully hand assembled to insure the highest level of craftsmanship
Alu-brushed anodized anti-vibration-resonance and non-magnetic chassis
Backlit “ayon” logo – front panel
All front & rear panel descriptions are engraved
4 line inputs, XLR, 1 pre out & 1 direct in - for pure power amp operation
Gold-plated heavy duty binding posts and input jacks
DC-Power filter
AC phase polarity control indicator
Metal remote commander
Chassis finish: black / chrome
Specifications-
Class of Operation   Triode or Pentode mode
Tube Complement 8x KT88, 6x 12AU7
Load Impedance   4 & 8 Ohms
Bandwidth   8Hz-70kHz
Output Power / Pentode mode   2 x 125 Watt
Output Power / Triode mode   2 x 80 Watt
Peak Output Power / Pentode mode   2 x 150 Watt
Frequency Response   15 Hz - 35 kHz / 0 dB
Frequency Response   10 Hz - 60 kHz / -2.5 dB
Input Impedance at 1 kHz   100K Ohm
Input sensitivity ( full power )   260mV
S/N ratio at full power   98 dB
Hum   0,003 V
NFB 0dB
Volume Control   Potentiometer
Remote Control   Yes
Inputs & Outputs   4 x Line IN, 1 x Direct IN, 1 x Pre Out
Dimensions (WxDxH) cm   50x40x25 cm
Shipping dimensions (WxDxH) cm   78x68x53 cm
Weight   44 kg
« Last Edit: 10 Feb 2014, 02:19 pm by jriggy »
thuhaile
Re: FS: Ayon Triton II Integrated
« Reply #1 on: 7 Jan 2014, 08:30 pm »
Hi, I'm interested.  How can one verify if this is version 2 or version 1?  Thanks.
jriggy
« Reply #2 on: 7 Jan 2014, 11:39 pm »
Hi thuhaile,
Great question! I had this very question once myself... Their are two ways (that I am aware of) to tell the difference between the Triton and the Triton II...
First, on the Triton(I), the word "Triton" is located on the lower RIGHT of the front panel, under the input selector knob. On the Triton II, the word "Triton" is located on the lower LEFT of the front panel under the volume knob.
Secondly --and most important. The Triton II is auto bias. With a "Bias setup" button and V1 thru V8 indicators on the back (see pic). The back of the Triton(I) has 8 separate biasing pots.
Besides that, my users manual says Triton II and Im sure the serial number could be verified as a Triton II.
I hope that helps. If you are interested in the amp, feel free to shoot me a PM.
 Jason
thuhaile
« Reply #3 on: 8 Jan 2014, 07:00 pm »
pm sent!
jriggy
« Reply #4 on: 6 Feb 2014, 01:27 am »
Buyer bailed... bumping before moving to Agon.
