0 Members and 1 Guest are viewing this topic. Read 10743 times.
Ah, sorry. I guess you meant the woofers for the Phoenix.
A chap named Gainphile did a W frame with 10" drivers, he might be able to give you dimensions.http://www.htguide.com/forum/showthread.php?36626-S14-4-Way-OB-using-Seas-and-Vifa-Zaph-drivers&p=557623&viewfull=1#post557623
I have a pair of Gershman Avantgardes using those same drivers (I assume). Interesting speakers.
From the looks of those T/S specs the FS is a little high and the Qts considerably higher than the Phoenix drivers.
This ought to mean less EQ is required.
Here's the in-room response of my Gershmans with (I assume) those woofers. As you can see they plummet below 50Hz. They aren't likely to do much better in a W frame. A W-frame has resonances which affect the upper frequency as well, so depending on the range you wish to cover there may be better choices.
A good rule of thumb in building an H-Frame is to keep the baffle depth < 1/2 of the width and height. For example, if your H frame enclosure measures 15" W x 15" H, keep the baffle distance from the front and rear of the enclosure less than 7.5". This assumes a symmetrical frame and helps quell any additional resonances you would then have to factor into the design....making the build more complicated.
matevana:Thank you for that. I still don't know which dimensions to begin to experiment with, because as I said, I'm a complete newbie. Any (ballpark) suggestions on that front?
Honestly, just go buy one of the Way Basics cubes for 20 bucks and throw in a baffle. It's an inexpensive test for one of your woofers and these dimensions generally work well with most 10". For testing purposes you can easily extend any of the dimensions with cardboard, but you may find this not necessary once you hear them. http://www.waybasics.com/shop/storage-cube-natural.html
Hey Matevana:For your H-frames, are you using the woofers wired in series or parallel?
