BDP-1 DEAD....
0 Members and 1 Guest are viewing this topic. Read 1270 times.
Gaustabl
BDP-1 DEAD....
« on: 3 Jan 2014, 03:33 pm »
I just got home and found my BDP-1 compleately dead. No lights or display........Is there an internal fuse if i remove the cover ?
Or should it just be returned to shop ?
best regards Lars
drummermitchell
Re: BDP-1 DEAD....
« Reply #1 on: 3 Jan 2014, 04:00 pm »
I'd try completely unplugging it for awhile as that might reset it.
That happened to me awhile ago,haven't had a problem since.
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDP-1 DEAD....
« Reply #2 on: 3 Jan 2014, 04:31 pm »
best regards Lars
Hi Lars
Email Mike Pickett as it may be a fuse.
[email protected]
james
Gaustabl
Re: BDP-1 DEAD....
« Reply #3 on: 3 Jan 2014, 08:39 pm »
Than You all for responding. I opened the player, removed the fuses, they turned out ok, so i put them back in and connected the powercord. I heard a faint buzz, but nothing happened. Grabbed the powercord and tried to see if there was a loose contact, and bending the powercord sligtly upward it came back to life. So far so good, i´ll have to keep an eye on the heavy wireworld cable so it does not put a strain on the contact.
 :D Lars
brucek
Re: BDP-1 DEAD....
« Reply #4 on: 3 Jan 2014, 08:47 pm »
Quote from: Gaustabl
tried to see if there was a loose contact, and bending the power-cord slightly upward it came back to life. So far so good,.......
It seems obvious that you should do more than be pleased that it's "so far so good", and in fact you should replace that power cord.
