primaluna tube monos
0 Members and 1 Guest are viewing this topic. Read 1391 times.
TJS
« on: 3 Jan 2014, 09:24 am »
hi...i have primaluna prologue 6 monoblocks, and primaluna pro 3 preamp, why one of the monoblock seem that lose power compared with the other one?? i already check the tubes, by swapping tubes between monos, but still produce the same result, i check the fuse...it still ok. i listened closely to the speaker that powered by that amp....it still producing sound but im very low volume. what is the problem?? is the output tranformer faulty?? really appreciate if anyone can help me, thx
Austin08
Re: primaluna tube monos
« Reply #1 on: 3 Jan 2014, 09:43 am »
Did you try to swap the pre-outof the preamp to amp from L to R?
Ericus Rex
« Reply #2 on: 3 Jan 2014, 01:42 pm »
+1.  Preamp tubes were my first thought too
TJS
« Reply #3 on: 4 Jan 2014, 11:27 am »
i did swap L and R out in preamp last nite....true, its preamp tube problems....i will try to find replacement tubes....thanks very much
Ericus Rex
« Reply #4 on: 4 Jan 2014, 02:59 pm »
Glad to hear it's a simple issue.    :thumb:
