Mullar/Amperex ECC83 Tube Flash
0 Members and 1 Guest are viewing this topic. Read 1347 times.
« on: 3 Jan 2014, 12:34 am »
Happy New Year to  everyone..
Does the amount one of these tubes flash when energized vary quite a bit from tube to tube ?  I picked up a clsely matched pairof Amperex ECC83's ('62, 165 series,  Heerlen factory)  and they do sound  great but  one flashed very brightly at  startup while the other  is a much dimmer flash.  .
Was wondering what you guys have experienced  with regards to this ?
-jay
« Last Edit: 3 Jan 2014, 04:22 am by Captainhemo »
Freo-1
Re: Mullar/Amperex ECC83 Tube Flash
« Reply #1 on: 3 Jan 2014, 12:43 am »
Normal behavior for Mullard/Amperex 12AX7 tubes.
« Reply #2 on: 3 Jan 2014, 12:55 am »
Hey Freo
I knew the flash was normal,  just wanted to make sure  it was  "normal" for one to flash birghtly while the other is much dimmer,  guess they all vary to a degree
-jay
Freo-1
« Reply #3 on: 3 Jan 2014, 02:35 am »
Yep, no worries.  They are very likely fine.  It is normal to have them behave differently.  Some will flash a lot, while others will show very little.
Octadyn
« Reply #4 on: 4 Jan 2014, 02:22 pm »
I bought 2 matched pairs of Gec CV6091's and only 1 tube has a bright flash on power up but the other 3 don't flash at all. I also have a pair of Amprex Bugle Boys where 1 flashes brighter than the other but I also believe these are rebranded RFT's.
Bottom line is it's nothing to worry about  :thumb:
shoot
« Reply #5 on: 9 Jan 2014, 05:56 pm »
needn't worry about it,It calls flash filament,in order to heat faster.
