Operating Voltage Range of Bryston Amps
0 Members and 1 Guest are viewing this topic. Read 2998 times.
klao
« on: 2 Jan 2014, 08:31 pm »
Hi James & Mike,
You might have seen my e-mails CC ed to you guys regarding my issues in calibrating the TorusPower AVR unit (and accidentally blowing the 28B amps -- hopefully only their circuit breakers).
What are the operating voltage ranges for these amps?
- the 28B-SST2 with 220V nominal rating
- the 7B-SST2 with 230V nominal rating
Many thanks,
Klao
  • The Demo is Everything!
    • http://www.bryston.com
Re: Operating Voltage Range of Bryston Amps
« Reply #1 on: 2 Jan 2014, 08:36 pm »
Hi James & Mike,
Many thanks,
Klao
Did you see the email from Torus?
james
klao
« Reply #2 on: 2 Jan 2014, 09:40 pm »
Got the e-mail just now, James.
I wish they did put those details for AVR calibrating in their instruction manual.   :?
Should I re-try turning on the amps, or should I have them sent in for inspection at the local distributor first?
Thank you again.
« Reply #3 on: 2 Jan 2014, 10:50 pm »
Thank you again.
Give Mike an email and see what he thinks.
james
klao
« Reply #4 on: 7 Mar 2014, 12:37 pm »
Well, James.  The amps turned out to be damaged beyond the breaker/power supply section.
Just sent Mike an e-mail and CCed you.
Hope to get his or your recommendation of Torus AVR nominal voltage setting to match my two amps.
The 28B's are now tapped to be 240V already.
« Reply #5 on: 7 Mar 2014, 01:58 pm »
OK thanks for the update - I will confer with Mike.
james
klao
« Reply #6 on: 9 Mar 2014, 12:59 pm »
Thanks in advance James & Mike.  I'm looking forward to hear your suggestion.
Hope the parts on output stage(s) for the 28B's aren't too expensive.   :cry:
klao
« Reply #7 on: 17 Apr 2014, 04:48 pm »
My e-mails must have been screened to Mike's junk folder; I never heard back from him.
Anyhow, I tried the 7B (230V) on the TorusAVR (which I had mis-calibrated) and blew that amp too.  :duh:
So all the 28B's and 7B have been repaired and their the voltage jumpers reset to 240V now.
The Torus AVR is being tested at the local distributor.  When it's all good, should I ask the tech people to set it to 240V to match the amps, even though my household voltate is 230V nominal (most of the time at 233V-235V)?
Thanks again, James.
klao
« Reply #8 on: 21 Apr 2014, 06:20 pm »
Hi James,
Glad to report to you that all my problems are solved.
Initially the local Bryston distributor's technician had informed me that the only available voltage settings for my 28B-SST2 amps were 220V & 240V.  That sounded strange, but I chose to let him do 240.  Since all my amps are still at the shop, I called to reconfirm and asked if they could be reset to 230V instead.  He said that's possible.  :D
As for the Torus AVR unit, the current distributor checked and correctly re-calibrated it for 230V, so it's fine now.  He said the actual output was alarming 290V, as result of my previous mis-calibrations. That explains why the amps were blown.
However, if you had a chance to chat with people at Tours and your own support team for the Bryston branded AVR unit, please pass along my suggestion.
Even if the AVR jumper voltage setting instruction is distributed on an as need basis, it should be much more detailed with procedures, tools required, and adequate harzard warnings, because a technically-challenged consumer like me could get the impression that calibrations are just for LCD panel accuracy readouts and has nothing to do with acual voltage output.
I made wrong conclusion that setting a particular jumper positions would somehow restrict the different oprating range of the AVR unit and would automatically confine or limit the actual voltage output, regardless of the LCD numbers that might have been mis-calibrated.  Well, it's an expensive lesson learned for me.   :(
« Reply #9 on: 21 Apr 2014, 06:29 pm »
Hi James,
Hi Klao,
Ok great to hear and thanks for the feedback - will pass along to the appropriate people.
james
jtwrace
    • TIPP YouTube Channel
« Reply #10 on: 21 Apr 2014, 06:36 pm »
Yikes!  That does sound expensive.   :cry:
