0 Members and 1 Guest are viewing this topic. Read 10684 times.
I tried a variety of resistors. Not a single one of them was better than without any resistor (and I can't quite describe what I heard with every one of them). I tried the RF choke (with and without resistors). I went back and forth with it and could never tell a difference. I experimented for over a year. Now, I have no resistors, no chokes, no fuses, less wiring, a satisfied curiosity and a voided warranty. It should be noted that my 3.7s are in a ~600sq', treated room and I employ an electronic crossover to direct the heavy lifting to a pair of subs. What works best for each of us is dependent on many things.
Took the resistors out. they sound bad. i stuck the coils back on that spot. Now back to smoooooth upper frequencies.. Maybe i need some better resistors then the ones Magnepan sends along?I also wonder if the rf coils have some resistance? as the tweets with the one ohm did not sound any different than with the coil.. except more stringent.The coil tweak is from: "Al Sekela tweak (5222 inductor)" discussed over at Audio Asylum in the Planar asylum.
And i have all the music i want 4,500 Lp and 2,700 CDs.. I have actually been dumping Lps just to reduce the load. Threw out 300 last month. Mostly Classical. Over the last year dumped about 750. But then i bought about 300 more to add in over the past year too.
Elizabeth that is a very impressive amount of music !! how do you store it all ?Russ
I started buying some new interconnects, and the sound is a little brighter. Finally decided to dig out (lucky i could find them!) The 1% resistors which came with my 3.6s.I installed them and the treble seems a little less.I miight buy some 5 watt resistors from Parts Express to play with to get the right setting.
