Enabling the Subwoofer Output in Bypass Mode for the SP 1.7
0 Members and 1 Guest are viewing this topic. Read 1946 times.
jimmyp58
I understand this maybe a 'hidden" feature on the SP 1.  I noticed in the manual (both the online version and hard copy that came with my unit) there is a section devoted to this feature in the Table of Contents (Page 21) but there is nothing typed on this page regarding this.
Can this be done and how can it be accomplished?
Please advise.
Thanks....
Jim
ec
« Reply #1 on: 8 Aug 2004, 03:07 am »
you have to use the discrete codes off the remote namely 060
so aim your remote at the SP 1.7 and press
"code"
"mute" for 0
"stereo" for 6
"mute" for 0
you should see on the SP 1.7 display a "sub bypass on / off" I remember correctly.
Just remember that a full range signal will be sent to your sub output so you will have to find a way to externally cross over  that output outside of the Bryston SP 1.7 (eg on the sub itself)
jimmyp58
« Reply #2 on: 8 Aug 2004, 03:21 am »
Thanks Eric....
gravy
  • -Scott
« Reply #3 on: 9 Aug 2004, 05:03 pm »
Quote from: jimmyp58
Thanks Eric....
Hi Guys,
Help me out - is this for enabling the sub during 2ch bypass?
ec
« Reply #4 on: 9 Aug 2004, 05:44 pm »
correct,
When you listen in 2 ch bypass mode with the sub bypass "off".  A full range signal will be sent out through the sub outputs.  By default ie (factory settings) there is no sub output when listening in 2 ch bypass mode.
gravy
  • -Scott
« Reply #5 on: 9 Aug 2004, 07:07 pm »
Quote from: ec
correct,
Thanks EC.
