Wanted:moderately priced brand name toslink cable for home theater system
0 Members and 1 Guest are viewing this topic. Read 1105 times.
DZetye
Looking for 1 to 2 meter Toslink- wireworld, audioquest or equivalent for my home theater system.  PM what you have and price.  Thanks for looking
srb
Not exactly sure what "moderately priced" is, but when you're looking at used offerings, also consider and compare to brand new Silflex Toslink Cables assembled in USA with Lifatec GmbH 470 strand glass fibers manufactured in Germany, which are precision industrial and medical cables without typical audiophile hype and prose.  (3ft./$69, 6ft./$79)
DZetye
Thanks, i will consider those but I was really looking for something around $20-$30 used.  I'm almost tapped out from Christmas.
Charles Calkins
I recommend that you look at the blue jeans cable site. Very good cables. If you don't like it you can return it and get a full refund.
                                                          Cheers
                                                         Charlie
DZetye
ok, thanks for the suggestions
highstream
Highly recommend the Silflex one.  Didn't do a comparison, but it has been very good with my dac to powered speakers 2.0 TV system.
Ericus Rex
...typical audiophile hype and prose.
Love that!  Especially the 'prose' part.  Well done!
srb
Another glass fiber Toslink to look at are the 280 strand cables available through eBay and other sources (search eBay for "glass toslink") for under $30.
In recommending the glass fiber cables I was trying to establish a quality level that won't be bettered even by the $300 Toslink offerings from typical audio cable manufacturers.
The problem is that these generic glass cables as well as the Silflex may actually be overkill for consumer Toslink transceivers, which to my knowledge, are not available in precision low-jitter grades unlike other numerous high-grade audio parts such as op-amps, digital volume control chips, etc.
I personally use Monoprice Premium Optical Toslink (plastic fiber) cables which work quite well, however the "Fancy" satin machined aluminum connector barrel, while quite beautiful, has too much mass and I have experienced breakage of the plastic part that mates with the optical jack from too much torque leverage.  Thankfully they haven't damaged the hard to replace jack.
DZetye
Thanks, everyone.  Found one.
