Loose RCA Connection on my Cyclops
0 Members and 1 Guest are viewing this topic. Read 1674 times.
jMelvin
« on: 26 Dec 2013, 11:23 am »
Not being a DIY type I'm hesitant to open up my Cyclops without asking here (or calling Klaus) but as the subject line says, I have a loose RCA connection .. it spins completely around. Can I tighten this back up with ease and without voiding the warranty?  Thanks.
Phil A
Re: Loose RCA Connection on my Cyclops
« Reply #1 on: 26 Dec 2013, 03:20 pm »
Klaus can answer the warranty questions.  I've had the top off to change tubes on my Candela preamp and all it took was the proper size hex wrench.  I did not look inside that much.  It depends if the back of the RCA jacks as to whether there is nothing around them (like circuit boards).  I've had bad solder joints on a couple of RCAs in the past.  One was real easy.  The other was an old Marantz 7300 OSE receiver where one of the preamp outs was bad (could hear the loose piece in the base).  I was not using them anyway (had an outboard amp on the center channel to make it easier on the receiver) and I opened it up and it would mean remover a circuit board above it to get to it.  I could have done it but since I don't do those things all that quickly and would want to be careful, I figured I'd end up taking more time than it was worth.  So other than the warranty issue, it is just a matter if it is easy to get to.  I've had my Modwright preamp and preamp power supply apart and changed tubes and changed fuses in the power supply.  Was relatively easy to get to.  From looking at the Odyssey website, they show the inside of the Cyclops and it should be easy to get to.
Phil A
« Reply #2 on: 26 Dec 2013, 03:21 pm »
Here's the Odyssey page for the Cyclops - http://www.odysseyaudio.com/products-cyclops.html
If you look at the second picture from the right you'll see it is clear around there.
Phil A
« Reply #3 on: 26 Dec 2013, 03:22 pm »
If Klaus has no problem with the warranty issue, it should not be bad.  Do not however open the case with the power connected.
jMelvin
« Reply #4 on: 26 Dec 2013, 09:42 pm »
Thanks Phil. Good advice to unplug first :wink:
 I'll contact Klaus about the warranty.
jMelvin
« Reply #5 on: 27 Dec 2013, 07:19 pm »
Done. Easy.
I’d like to thank Klaus for answering my email so quickly and giving me the go-ahead to open up my Cyclops (SE+ w/ps upgrade) for this very simple fix. Klaus .. you’re the best!
Although I’m not a DIY type, I have opened up my fair share of components and can comfortably say the build on this integrated is superb .. it just reeks of quality and the workmanship is top-notch. The photos on the Odyssey website don’t do this little beast justice. Yeah, I’ve read all this before but to see it with my own eyes really put a big smile on my face. Klaus delivers bang-for-the-buck like no one else.
While it’s perhaps not for everyone, I wouldn’t hesitate in recommending the Cyclops to anyone looking to keep it simple. Fantastic sound quality coupled with great build quality .. what’s not to like?! Love mine.
