connecting to hdd on bdp-1
0 Members and 1 Guest are viewing this topic. Read 1020 times.
Gaustabl
« on: 25 Dec 2013, 05:17 pm »
Hello.
I try to connect to my external hdd connected to my bdp-1, but i get an error. "there was a problem connecting to xxx.xxx.xxx.xxx" no shared volumes ..........
what could be the problem ?
best regards Lars
  • The Demo is Everything!
    • http://www.bryston.com
Re: connecting to hdd on bdp-1
« Reply #1 on: 25 Dec 2013, 09:13 pm »
Hello.
best regards Lars
Hi
Is it a USB drive?
james
unincognito
    • bryston.com
« Reply #2 on: 25 Dec 2013, 10:51 pm »
Hi Lars,
The BDP will only create the network shares during startup, the proper sequence is to plug the drive into the BDP and then turn the BDP on.
Chris
Gaustabl
« Reply #3 on: 26 Dec 2013, 09:54 am »
Hello.
It is working now, thank you for replying.
best regards Lars
