WTB: cheap SET stereo amplifier- purchased.
0 Members and 1 Guest are viewing this topic. Read 5286 times.
raysracing
« on: 25 Dec 2013, 03:15 am »
Hoping to luck out and pick up someone's DIY set amp for my new/used Omegas with Hemp drivers. My budget is low so hoping to put a little dinner money in your pocket.
Edit:Thanks- found and bought amp from fellow AC member locally
« Last Edit: 14 Feb 2014, 01:23 am by raysracing »
ClefChef
Re: WTB: cheap SET stereo amplifier
« Reply #1 on: 30 Dec 2013, 12:15 am »
Check out MusicalParadise.ca or MiniWatt N3 on ebay. Doubt you will find DIY cheaper than that.
Jeffr1966
« Reply #2 on: 31 Dec 2013, 04:28 pm »
not sure how much you are looking to spend but I have a DIY (NOT built by me) SET using KT120 tubes ... seems to be a very solid build (large transformers - probably 25lb) but I recently purchased a Shindo Montille/Aurieges combo so this is unused
I have a matching tube preamp as well
be looking for $1000 for the pair (amp and pre) and would prefer to sell together
Ericus Rex
« Reply #3 on: 31 Dec 2013, 06:54 pm »
Music Reference sells a SET 2.5W EM7 kit for $750.  Here's a youtube vid of him talking about it:
http://www.youtube.com/watch?v=7qg9ot20EdA&feature=c4-overview&list=UUhBOdsRsM7YDnU2CHsgBG-g
raysracing
« Reply #4 on: 2 Jan 2014, 03:41 am »
Thanks guys, but $150 to $250 is more my range.
Ray
Jeffr1966
« Reply #5 on: 2 Jan 2014, 03:52 pm »
tough to find in that price range ... a GOOD SET is somewhat $$$ to make even DIY
good luck!
Jeff
ClefChef
« Reply #6 on: 2 Jan 2014, 08:11 pm »
Problem with SET is output transformers, and decent ones cost money. The price of the amp is going to be determined by the quality of iron. $150 could get you cheap used Chinese el84 with no name parts, or maybe salvaged console amp that requires some work.
raysracing
« Reply #7 on: 3 Jan 2014, 02:59 pm »
Got it. I wanted a cheaper one as a test as I know no one local with one to try. Bummer.
musicdre
  • reality is the base
    • art site
« Reply #8 on: 29 Jan 2014, 04:44 am »
look around for the musical paradise MP-301.  its a an excellent sounding SE amp, and sells new for about $350.  i have seen used ones listed recently  on ebay and other well known listing spots.  you may be able to get one at about the high end of your $ range.
good luck in your endeavor.  -andre
hatrack71
  • beyond help..
« Reply #9 on: 30 Jan 2014, 12:03 pm »
Actually, the Miniwatt N3 is touted as being pretty good in your price range. It might as least get you down the rabbit hole.  :)
Goosepond
  • Virna!
« Reply #10 on: 30 Jan 2014, 09:09 pm »
I've got a MP 301 Mk2 (EL34 version) I bought a couple of years ago that I'm not using. I bought it to use with a bedroom system/headphones and have never used it much.
Gene
raysracing
« Reply #11 on: 1 Feb 2014, 12:42 pm »
I started down a different path looking at building two bucket subs, but if I can get a SET at my price then I will redirect funds again. Thanks for advise and definitely hit me up Gene. I am most likely between a MP MK301 Mk2 and a Miniwatt N3
musicdre
    • art site
« Reply #12 on: 1 Feb 2014, 01:32 pm »
imho, a SET is higher priority than subs.  subs are like frosting.  SET is the heart of the system.
but all the best whichever fork you take here.
raysracing
« Reply #13 on: 1 Feb 2014, 04:54 pm »
I have read a couple accounts of Omega's bass output improving with less powerful SET amps. Curious.
rklein
  • My finest audio piece ever!!
« Reply #14 on: 4 Feb 2014, 04:39 pm »
maybe a used one of these... they are $539 new but used...
http://www.bottlehead.com/store.php/products/single-ended-experimenters-kit
Randy
raysracing
« Reply #15 on: 9 Feb 2014, 01:31 am »
Randy
Non available now used and I do not have the time to build an amp these days.
I am waiting on an auction tomorrow for a MP-301 and if it goes too high I think I will buy the latest MP301 new.  Hope I am home when auction ends! My budget (this week) is about $400.
jackthecat121
« Reply #16 on: 11 Feb 2014, 09:59 am »
I have a twin Audio el34/kt 66 SET integrated amp with upgrade transformer. Super sweet.
Twin Audio used to haveacircle here. Google it.
$500 plus shipping OBO.
Ericus Rex
« Reply #17 on: 11 Feb 2014, 04:52 pm »
esnipe.com is your friend.
raysracing
« Reply #18 on: 14 Feb 2014, 01:21 am »
Thanks for offer. A local guy hit me up and I bought his mp301mk3 just a few minutes ago.
Ray
