VMPS Speakers For Sale...!
0 Members and 2 Guests are viewing this topic. Read 550435 times.
Stimpy
Re: VMPS Speakers For Sale...!
« Reply #720 on: 17 Dec 2016, 06:52 pm »
VMPS RM-30M Single CENTER Speaker  - $375 (Century City/LA, CA)  $375
http://losangeles.craigslist.org/wst/ele/5913980994.html
"Photo showing the Speaker on its side is the actual speaker.
Cabinet is Cherry.
This offering is a SINGLE RM-30M, with the 10" side firing woofer. Was used horizontally for a CENTER CHANNEL. There is NO BETTER Center for under $2000
Ribbon Tweeter, Planar Midrange Panels, Dual 6" woofers, Single 10 up-firing Woofer, and Passive Radiators.
Actual Speaker in HT Photo, placed horizontally, with 10" woofer firing UP.
Cherry finish Original retail $2500
Incredible Voice Clarity when used as a CENTER Speaker.
"The RM 30 is a speaker that can match the dynamic capabilities of competent horns, the immediacy of electrostatics and planar-magnetics, and the fine detailing and imaging of the best dynamic designs." - Positive Feedback
RM30 is 50 cm (20") deep, but can be placed directly against a back wall if needed. The FST, Soundcoat and 10" Megawoofer are all standard. M and C versions are exactly the same except for the M's sidefiring woofers. The large cabinet of the C version provides good quality bass flat to 39 Hz from the four 16 cm WCF woofers. The M version cuts off at 32 Hz. The RM30 uses three 2.4 Ohm midrange panels wired in series. The FST is at the top of the column. The C version is a true line source, the M series is a slight departure with its side-firing woofer. The active 16 cm is a specially developed WCF 16 cm Megawoofer. They offer higher power handling, cleaner sound and have the ability of not bottoming out no matter how hard they are driven.
The RM30's are extremely flexible of placement, including touching the back wall if necessary.
VMPS RM30 M & C versions
This loudspeaker answers the requests from audiophiles since early 2002 for a speaker priced between, & more attractive than the RM2 & RM40. Its premium blending of price, performance, flexibility, & cosmetic beauty promises more than anything currently available.
· Price includes Free Swinging Tweeter & SoundCoat.
· Performance: maximum output just below the RM40 combined w/a new reference in staging, imaging, musicality, nearfield listening, & disappearing qualities.
· Flexibility: the standard C model has bass extension in the high 30s. The M version (additional 10"side firing MW, same cabinet) extends to the high 20s & has a feature to minimize bass modes. Details on both versions below.
· Cosmetic Beauty: at 20cm wide it's the narrowest VMPS ever & 5 cm narrower than the 626R standmount. At 122 cm it's only 8 cm above the RM2 and a perfect match for video monitors. Depth is a moderate 50 cm.
Driver Array: the sequence below matches the driver positions on the baffle, from the top down.
1. Standard FST tweeter, previously standard only at the RMX.
2. 3 vertical Neo mids.
3. Dual active 16 cm, the ideal diameter in the critical transition range, w/punchy, quick midbass."
Stimpy
« Reply #721 on: 17 Dec 2016, 06:57 pm »
VMPS RM-40 Ribbon Monitor Floor Standing Speaker  -  (Century City/LA, CA)  $2395
http://losangeles.craigslist.org/wst/ele/5913977938.html
""The speakers were so impressive that they moved at least one judge to tears." - Tech TV
With the VMPS Ribbon Monitor 40 we set a new standard for quality, value, and the latest technology wrapped into one slim, elegant package.
This 109 kg, 168 cm tall floorstanding speaker boasts the 25cm Woven Carbon Fiber Megawoofer lowbass and 25cm WCF midbass in a symmetrical array with four 20cm Neodymium midrange ribbon panels (280 Hz to 7 kHz) and one Free Swinging Tweeter (flat to 25 kHz) in a column only 32 cm wide and 43 cm deep. Thin dimensions and full driver symmetry guarantee pinpoint imaging and a soundstage both wide and deep, with layering and detail that is simply breathtaking. Cabinetry is 38 mm thick MDF baffles (plus 28 mm sides and top) treated with Soundcoat for 10 dB less panel vibration. The result is 24 Hz bass with ultraclean 115 dB/1m output levels at an unprecedented low price for such achievement.
There are three ways to operate the RM 40, so-called because of its 40 inch vertical ribbon mid/tweeter array. The first is full range, with a single amplifier as a source. The system presents a steady 4 Ohm load, resistive above 166Hz, with 90dB/1W sensitivity and enormous output and dynamic range. Second, more ambitious audiophiles can easily switch the system to the biamp/biwire configuration and run a separate bass amp through the speaker's passive bass and mid/treble crossovers which, by the way, consist of all premium parts such as Axon polypropylene caps and hi-Q Erse 14 gauge laminated core inductors. The third option is biamping with the passive bass crossover removed, an outboard 24 dB/octave electronic crossover driving the separate bass amp, and a second amp running the ribbon panels through their builtin 6 and 12 dB filters.
No matter if your tastes run to high-end Music or Home Theater, once you have heard the sheer responsiveness and velocity of our unique handbuilt woofers, exclusive high efficiency Neo ribbon midranges and spiral ribbon tweeters, you won't want to go back to dynamic speakers regardless of price.
The RM 40 was the centerpiece of our 2002 Consumer Electronics Show demonstration room which won "Best of CES" from TechTV, the media arm of the Electronics Industry Association, host of the Show. The RM 40 won as best High End Audio product in a field of 261 exhibitors (of all High End products, not just speakers, although our competitors in that regard all ran 5 to 20 times our price) with 35 total products nominated. A field of 26 judges canvassed the Show for winners, giving VMPS the nod in High End Audio."
Stimpy
« Reply #722 on: 17 Dec 2016, 07:02 pm »
VMPS RM 40 Speakers  - $2100 (Corona/Inland Empire, CA)  $2100
http://inlandempire.craigslist.org/ele/5913937900.html
"Selling a pair of Audiophile VMPS RM40 Floor standing Speakers in good condition. All drivers work perfectly. These are great sounding high end speakers with ribbon midrange drivers and tweeters. Vocals and instruments are clear, precise, with an incredible sound stage. Take a listen for yourself. Ready for audition. The speakers are very heavy and weigh 240 lbs. each with the following dimensions 66" tall x 17" deep x 12.5" wide."
Stimpy
« Reply #723 on: 17 Dec 2016, 07:09 pm »
REPOST
VMPS RM2 Tower Ribbon Monitor Speakers  -  (Spring Valley/San Diego, CA)  $2650
https://sandiego.craigslist.org/esd/ele/6092049424.html
"A very rare pair of monitors for sale. These are rated at 200 watts each. This version of the RM2's have the more desirable spiral tweeters. Both in very good condition, both sound perfect."
« Last Edit: 18 Apr 2017, 12:52 am by Stimpy »
Stimpy
« Reply #724 on: 31 Dec 2016, 07:18 pm »
REPOST
http://inlandempire.craigslist.org/ele/5931859857.html
Stimpy
« Reply #725 on: 31 Dec 2016, 07:22 pm »
REPOST
https://inlandempire.craigslist.org/ele/6060256586.html
Vintage VMPS smaller subwoofers sub  -  (Inland Empire, CA)  $250
http://inlandempire.craigslist.org/ele/5842512263.html
"I have for sale a pair of VMPS passive subwoofers. These are in great condition and sound terrific. This is a 12" diameter non-powered subwoofer with a 12" active radiator in front and a 12" passive radiator in bottom. VMPS calls it their "Smaller Subwoofer" It measures 16" wide, 16" deep and 27" tall with a nice walnut cabinets.
VMPS has been known for making outstanding sub woofers and speakers for nearly 3 decades. The subwoofer is rated at 8 ohms and the frequency range is 28-150Hz. These will take just about all the power you can throw at it (up to 250 watts rms) and the bass is really tight.
I had all the drivers (main and passive radiators) refoamed a few years ago by VMPS themselves. I removed the speakers from the cabinets and shipped them. The passive radiators are mounted in a "slot" at the bottom of the speaker cabinet. VMPS informed me that the bottom of the cabinet needed to be knocked off to access them, then screwed back on when replaced. I've shown the bottom with the screws in the pictures.
Asking $250
If the listing is up they are still available."
« Last Edit: 11 Apr 2017, 11:22 pm by Stimpy »
Stimpy
« Reply #726 on: 31 Dec 2016, 07:26 pm »
REPOST
http://losangeles.craigslist.org/wst/ele/5938324334.html
Cabinet is Cherry.
Stimpy
« Reply #727 on: 31 Dec 2016, 07:28 pm »
REPOST
http://losangeles.craigslist.org/wst/ele/5938323780.html
Stimpy
« Reply #728 on: 14 Jan 2017, 03:53 pm »
VMPS QSO 626 Center Channel Speaker  -  (Aurora, Illinois)  $75 OB
http://www.ebay.com/itm/162356840753?rmvSB=true
"VMPS QSO 626 Center Channel Speaker. Sounds great!!!!! Looks almost new. Asking $150 OBO"
Stimpy
« Reply #729 on: 14 Jan 2017, 03:57 pm »
Repost & Price Drop
VMPS Tower 2 speakers Special Edition Local Pick up  -  (Chicago, Illinois)  $777.00
http://www.ebay.com/itm/311772935007?rmvSB=true
"A nice pair traded in all original. The foam may need to be replaced but wanted to show an example of a really nice unit of this age. Very nice sound for low price."
John Casler
Stimpy
« Reply #731 on: 14 Jan 2017, 04:04 pm »
High end stereo-Krell Reference 64  -  (Hyde Park)  $???
http://hudsonvalley.craigslist.org/ele/5953797145.html
"I must unload all my stereo equipment due to moving. All items are as is but do not be discouraged as all are in perfect working condition. I will not ship this is pick up only! I fully expect any serious buyers to come and hear the system for themselves before purchasing. I would prefer to sell the system as a whole but will consider individual pieces. Up for sale is: Krell KSA250(sold), VMPS Tower 2 speakers, Sunfire True subwoofer MK2, PS Audio P600 Power Plant, Krell Reference 64 DAC(best ever made)$14,000 when it was new, Kinergetics Research Transport KCD-55T, Threshold Model SL10 preamp with outboard power supply, dbx 3bx series 2 dynamic range expander. All interconnects and high end monster cable speaker wire, along with 3 upgraded power chords, 6 tier stereo rack and amp stand for amp are included if system is bought as a whole. This is my most treasured possession and I am heartbroken to sell it. It will not disappoint as a whole system. I listen to mainly metal and rock but this system will unveil sounds you have never heard before in whatever you listen to. Please don't waste my time if you are not a serious buyer. My loss is your gain big time!! Listing as good condition due to age. Will send pictures via text if requested. Krell KSA250 is sold all other equipment still available. Email for individual prices or offers."
Stimpy
« Reply #732 on: 14 Jan 2017, 04:09 pm »
VAMPS SPEAKER  -  (Mt. Pleasant/Milwaukee, WI)  $1900
http://milwaukee.craigslist.org/ele/5927663500.html
"VAMPS SUPER TOWER 11a/R Speaker in good condition. All Woofer surround has been reformed sound s and look s good"
Stimpy
« Reply #733 on: 14 Jan 2017, 04:12 pm »
VMPS Original Subwoofer  -  (Minneapolis, MN)  $100
http://minneapolis.craigslist.org/hnp/ele/5927259939.html
"Early 90s passive subwoofer in black cabinet. With the right amp and crossover this will rattldowse your windows."
Stimpy
« Reply #734 on: 14 Jan 2017, 04:19 pm »
REPOST
VMPS RM2 Tower Ribbon Monitor Speakers  -  (Spring Valley, CA)  $2650
http://sandiego.craigslist.org/esd/ele/5950632549.html
« Last Edit: 15 Jan 2017, 03:12 am by Stimpy »
Stimpy
« Reply #735 on: 14 Jan 2017, 04:22 pm »
REPOST
VMPS RM-40 Ribbon Monitor Floor Standing Speaker  -  (Century City, CA)  $2395
"These have the rare Dibble Cabinets, and OXO (Outboard Crossovers)
Stimpy
« Reply #736 on: 14 Jan 2017, 04:25 pm »
VMPS 626R Spiral Tweeter (Single Center) Speaker  -  (Century City, CA)  $159
http://losangeles.craigslist.org/wst/ele/5945989797.html
"I have a Gloss Black VMPS 626R w/Spiral Ribbon Tweeter which was used as a Center Channel.
Great for REALLY Hearing Dialogue CLEARLY.
Nothing approaches it for clarity and transparency at this price.
Nice Condition This model has a grill and tweeter mask."
Stimpy
« Reply #737 on: 14 Jan 2017, 04:28 pm »
REPOST
VMPS RM 40 Speakers  -  (Corona, CA)  $2100
http://inlandempire.craigslist.org/ele/5949668933.html
« Last Edit: 15 Jan 2017, 03:13 am by Stimpy »
Stimpy
« Reply #738 on: 14 Jan 2017, 04:37 pm »
Vintage VMPS smaller subwoofers sub  -  (Walnut, CA)  $250
http://inlandempire.craigslist.org/ele/5939079991.html
NO PICTURES - (See Original Sub AD Posted Earlier Today For Example)
Asking $250
Stimpy
« Reply #739 on: 14 Jan 2017, 04:45 pm »
REPOST
VMPS 626 Jr SPEAKER 626jr speakers vmps626jr  -  (Chinatown/Vancouver B.C. Canada)  $1000
https://vancouver.craigslist.ca/van/ele/5956503479.html
"Pair of Ribbon planar midrange speakers with great warmth and upgraded carbon fiber woofer for a nice deep tight punchy bass. Vmps626 jr Adjustable tweeter and mid cross-over. The crossover adjustments are in back as pic shows. Compact speaker or HUGE bookshelf? :) have receipt but only 1 box( sorry)...FIRM"
« Last Edit: 15 Jan 2017, 03:14 am by Stimpy »
