0 Members and 2 Guests are viewing this topic. Read 550433 times.
I know a fellow looking for a pair of 626R's if anyone has, or sees some for sale.
May be a possibility?http://vancouver.craigslist.ca/van/ele/5771475963.html"VMPS 626 Jr SPEAKER's - $1000 ($757 USD) (Chinatown - Vancouver, Canada)Ribbon planar midrange speakers with great warmth and upgraded carbon fiber woofer for a nice deep tight punchy bass. Vmps626 jr Adjustable tweeter and mid cross-over. The crossover adjustments are in back as pic shows. Compact speaker or HUGE bookshelf? have receipt and box(only 1box , sorry)...FIRM"
VMPS LARGERSUB with Megawoofers, Light Oak - (Green Bay, Wisconsin) $349.99http://www.ebay.com/itm/VMPS-LARGERSUB-with-Megawoofers-Light-Oak-/112066390984?hash=item1a17ad6bc8:g:-00AAOSwqfNXkqFj"Call with any questions (920)494-8999 or 'contact us' at hifiheaven.netCheck out and "like" our FACEBOOK page for great deals and news!!PREOWNED - LIGHT OAKVMPS LARGERSUB with MegawoofersThe Passive radiator has tear in surround that has been glued"
VMPS RM-30M Floorstanding Speakers - (Los Angeles, CA) $1695http://www.usaudiomart.com/details/649294849-vmps-rm30m-floorstanding-speakers/"This offering is the RM-30M, with the 10" side firing woofer"The RM 30 is a speaker that can match the dynamic capabilities of competent horns, the immediacy of electrostatics and planar-magnetics, and the fine detailing and imaging of the best dynamic designs." - Positive FeedbackRM30 is 50 cm (20") deep, but can be placed directly against a back wall if needed. The FST, Soundcoat and 10" Megawoofer are all standard. M and C versions are exactly the same except for the M's sidefiring woofers. The large cabinet of the C version provides good quality bass flat to 39 Hz from the four 16 cm WCF woofers. The M version cuts off at 32 Hz. The RM30 uses three 2.4 Ohm midrange panels wired in series. The FST is at the top of the column. The C version is a true line source, the M series is a slight departure with its side-firing woofer. The active 16 cm is a specially developed WCF 16 cm Megawoofer. They offer higher power handling, cleaner sound and have the ability of not bottoming out no matter how hard they are driven.The RM30's are extremely flexible of placement, including touching the back wall if necessary.VMPS RM30 M & C versionsThis loudspeaker answers the requests from audiophiles since early 2002 for a speaker priced between, & more attractive than the RM2 & RM40. Its premium blending of price, performance, flexibility, & cosmetic beauty promises more than anything currently available.· Price includes Free Swinging Tweeter & SoundCoat.· Performance: maximum output just below the RM40 combined w/a new reference in staging, imaging, musicality, nearfield listening, & disappearing qualities.· Flexibility: the standard C model has bass extension in the high 30s. The M version (additional 10”side firing MW, same cabinet) extends to the high 20s & has a feature to minimize bass modes. Details on both versions below.· Cosmetic Beauty: at 20cm wide it’s the narrowest VMPS ever & 5 cm narrower than the 626R standmount. At 122 cm it’s only 8 cm above the RM2 and a perfect match for video monitors. Depth is a moderate 50 cm.Driver Array: the sequence below matches the driver positions on the baffle, from the top down.1. Standard FST tweeter, previously standard only at the RMX.2. 3 vertical Neo mids.3. Dual active 16 cm, the ideal diameter in the critical transition range, w/punchy, quick midbass.Passive Radiators: tunable, down firing, slot & mass loaded (classic VMPS). The ultra-slim baffle requires dual 16 cm PRs (a VMPS first), mounted inline front to back. Mass adjustments are performed on both or only one PR (the front), providing finer & smoother tuning increments.Woofer Options: apartment dwellers, persons with 1st octave room modes, persons desiring moderate bass extension, &/or persons already possessing a quality subwoofer will be pleased w/the C model’s high 30 Hz cutoff. The M model’s side-firing 25cm 80oz-magnet Megawoofer extends to the high 20 Hz range. The mirror-imaged L-R speakers are reversible, allowing the 25cm basses to fire either inward or outward to maximize the averaging of room modes, a'la RM/X. We generally recommend:Includes:Speakers and front grills.Looking for local pick-up or can deliver to 50mi radius to Century City CA."
Custom Home speakers & 15 inch frames,6 inch cones - (San Francisco Bay Area, CA) $50 - $100http://sfbay.craigslist.org/eby/ele/5866927265.htmlhttp://sfbay.craigslist.org/eby/ele/5866916532.html"Yes $50 each for cabinets made by VMPS. Historically great quality at a fantastic price. Some drivers available...I have tons of VMPS stock left from the Factory."
