Audioquest Wild Cat 1.5M Tone Arm Cable $45 SOLD
0 Members and 1 Guest are viewing this topic. Read 462 times.
Mister Pig
  • "when pigs fly"
    • Affordable Audio/Positive Feedback Online writer
« on: 22 Dec 2013, 04:48 pm »
This is an Audioquest Wild Cat phono cable, with standard 5 pin DIN connector, and RCA jacks. Overall condition is excellent, with no kinks or tears, and minimal wear on the grounding spade.
This is the product description from Audioquest.
LID PERFECT-SURFACE COPPER CONDUCTORS (PSC): Perfect-Surface Copper has an astonishingly smooth and pure surface. Proprietary metal-processing technology protects the wire’s surface at every stage of drawing and fabrication. When high-purity low-oxide copper is kept as soft, pure and smooth as possible, it becomes a wonderfully low-distortion conductor. For over 30 years AudioQuest has pioneered the use of superior metals; yet even we were surprised by this huge leap in performance. PSC clearly outperforms previous AQ metals that cost over ten times as much. Electrical and magnetic interaction between strands in a conventional cable is the greatest source of distortion, often causing a somewhat dirty, harsh sound. Solid conductors are fundamental toward achieving Wildcat’s very clean sound.
POLYETHYLENE AIR-TUBE INSULATION: Any solid material adjacent to a conductor is actually part of an imperfect circuit. Wire insulation and circuit board materials all absorb energy (loss). Some of this energy is stored and then released as distortion. All of Wildcat’s conductors use PE Air-Tube Insulation because air absorbs next to no energy, and Polyethylene is low-loss and has a benign distortion profile. PE Air-Tube Insulation causes much less of the out-of-focus effect common to other materials.
TERMINATIONS: Wildcat’s gold-plated RCA plugs use a proprietary design that eliminates the distortion caused by the extra contact inside most plugs. Because the ground shells are stamped instead of machined, the metal can be chosen for low distortion instead of machinability. A combination of these major ingredients, and many more subtle details add up to explain how Wildcat can sound so clean, clear and dynamic.
Here is a picture of the cable coiled up in front of the turntable.
« Last Edit: 25 Dec 2013, 07:31 pm by Mister Pig »
