0 Members and 1 Guest are viewing this topic. Read 1826 times.
So I run the device manager and it can't find the hardware.
Shouldn't I just be able to direct iTunes or a flash drive to go to the usb device without downloading any drivers?
Soundcard is an ancient soundblaster from the early 2000s.
What is the model number of the DAC? Are you sure it's compatible with XP and usable without any drivers from the manufacturer?
Letitroll, see my addition to the prior post, in case you didn't get there already. Was switching between screens and for some reason forgot to note where in 'Options' to check for the settings. Hope you got it working.
I did have a couple of drop outs using the flash drive, which are wav files for the most part. Should I be putting all this on an external hard drive as a makeshift music server.
