PLC•1 MKII Remote Passive Line Controller.Volume, mute, inputs and tape monitor at your finger tips. The PLC•1 MKII is the ultimate passive audio system controller.
This unit is just couple months old and the only reason i am selling it is because my tube dac has a very low output.
The RC•1a Remote Control system allows for complete control without ever leaving your listening chair. Volume, Mute, Input scroll (up/down), Tape Monitor, and direct access to any input are at your fingertips. A 12v trigger output can also be controlled by the remote to turn on/off other devices (amplifiers, etc.)
Specifications
Audio Inputs 4 pairs standard (one of which can be configured as HT bypass) 1 pair tapeAudio Outputs2 pairs variable 1 pair tape (fixed level)Accessory Outputs12v DC Trigger Potentiometer 10k ohm ALPS Blue Velvet(motorized)Remote Control Range30 ft Power Supply14v AC/850mADimensions8.50"w x 2.75"h x 6.50"d
Most recent review:
http://www.avrev.com/home-theater-preamplifiers/stereo-preamps/channel-islands-audio-plc-1-mkii-remote-passive-controller-review.html“Sonically, the PLC-1 draws little attention to itself. It’s such a reserved-sounding piece, I did not find myself being drawn unduly to just one segment of the frequency spectrum… The PLC-1 retrieved the vocals in a most satisfactory fashion. If a person has quite a number of older discs where vocals are prominent, then I would suggest mating the PLC-1 and D-200’s with a warmer sounding CD player, since the Channel Islands gear will bring plenty of focusing
SOLD
