Looking for external 12v trigger
0 Members and 1 Guest are viewing this topic. Read 1484 times.
Nocturne79
« on: 17 Dec 2013, 02:40 pm »
Hello everyone I am not sure if this has been posted here to not and if so I apologize for repeating it.  I am looking for, I think, a 12v trigger that I can use to have my synergy amp turn on when I turn on my marantz av7701.  If something like this exists and if anyone has any input I would greatly appreciate it,  thank you
Nocturne79
avahifi
    • http://www.avahifi.com
Re: Looking for external 12v trigger
« Reply #1 on: 17 Dec 2013, 09:19 pm »
I have been told that there are some 120V AC power terminal strips that can be activated by a 12V trigger.  Plugging the amp into one of these should do the job for you, assuming a 15 amp rating on the AC outlet strip.
Frank Van Alstine
Nocturne79
« Reply #2 on: 18 Dec 2013, 01:01 pm »
Thank you sir,  I will look into that.
Merry Christmas
« Reply #3 on: 18 Dec 2013, 04:22 pm »
While maybe not the best arrangement, if the Receiver has a switched out let you could use that. Or, while it does add an extra piece of gear, it's small, relatively inexpensive, and works well for infra-red. I've been using one with two of the plug-ins for a couple of years now (not on my stereo equipment) without incident.  I picked them up at Fred M. You can also add up to 8 different outlets for 1 remote unit.
http://www.amazon.com/GE-51135-Indoor-Receiver-Keychain/dp/B00032AVNQ/ref=sr_1_fkmr1_1?s=electronics&ie=UTF8&qid=1387383196&sr=1-1-fkmr1&keywords=GE+infra-red+controlled+outlet
Something to think about anyway.
