Question on the 7F
0 Members and 1 Guest are viewing this topic. Read 1503 times.
Guy 13
Question on the 7F
« on: 12 Dec 2013, 03:29 am »
Hi Louis and all Audio Circle members.
Where can I find information on the enclosure that use the 7F ?
I am looking for pictures, dimensions for a floor standing unit.
Thanks.
Guy 13
Louis O
Re: Question on the 7F
« Reply #1 on: 15 Dec 2013, 07:37 pm »
Hi Guy,
How large and do you want narrow or wide baffle?
I will put it together for you.
Louis
Guy 13
« Reply #2 on: 16 Dec 2013, 08:37 am »
Hi Guy,
Louis
In my original post I only asked for recommended dimentions
for the enclosure for the 7F.
I might be considering making my own enclosure
with the 7F, I bought from you.
Another question, while I've got your attention:
Does the Super Five Monitor uses the 5F driver?
And the 7F, do you use it in some of your current production enclosures.
Thanks.
Guy 13
Canada Rob
« Reply #3 on: 16 Dec 2013, 04:32 pm »
Hello Guy,
The Super 5 Monitor, and all the Super 3 series use the RS5 driver which is only available in finished Omega speakers.
Louis O
« Reply #4 on: 22 Dec 2013, 08:00 pm »
Hi Guy 13,
Thanks and Canada Rob is correct. I use the RS5 on Omega complete speakers and the 7 series which will be out soon has a version of The Model 7's which is a little different.
The all new 8" driver will be on my bench soon after Christmas.
Thanks again,
Louis
