is Bluesound filling the vacuum left by squeezebox?
0 Members and 1 Guest are viewing this topic. Read 17651 times.
BobC
Re: is Bluesound filling the vacuum left by squeezebox?
« Reply #40 on: 25 Sep 2015, 01:13 pm »
Node 1 > Wireworld Supernova 7 Optical > Schiit Gungnir > Odyssey Audio Candela and Stratos Mono Ex > Martin Logan Ascent i's
I continue to be pleased now that I am more familiar with the app.  You basically build a playlist versus just tapping the files like Squeezebox.  Has advantages and disadvantages, but meets my need.
I have both iPhone and Android tablet versions.  Both function the same, but for some reason the iPhone seems to be a bit more stable.....sometimes I need to reload the Android version.
I DID have a problem losing my library and reindexing....and was cursing BS, but the tech support was great.  Turned out it was a problem with my PC settings, and the tech made an appointment to take remote access of my PC the adjust the settings.  No problems since.
I like the Node 2.  Wish I had it, but not going to switch....especially since the Node 1 works well and I already bought the $180 optical cable!!!
