unifield 3 - dacron
0 Members and 1 Guest are viewing this topic. Read 1378 times.
scb
unifield 3 - dacron
« on: 10 Dec 2013, 10:44 pm »
I'm experimenting with the dacron fill. I just took it all out of my Unified 3s and I'm going to check a bunch of tracks out with no filling at all.
For the Unifield 3 owners here, did you remove the dacron? How much?
scb
Re: unifield 3 - dacron
« Reply #1 on: 18 Dec 2013, 01:33 am »
huge difference with all the dacron taken out. Bass is fuller and more present
es347
  • ..I've got my eye on you...which one you say?
« Reply #2 on: 18 Dec 2013, 02:22 am »
I have played with the stuffing in my VR5s and prefer oyster.... :duh:  Seriously I have found that the amount to remove or install is very much room-dependent so there is no absolute answer..
